Datasheet LT1219CN8 - Linear Technology Даташит ИС, OP усилитель, PREC, DIP8, 1219 — Даташит
Наименование модели: LT1219CN8
Купить LT1219CN8 на РадиоЛоцман.Цены — от 397 до 5 349 ₽ 21 предложений от 14 поставщиков Op Amp Single GP R-R I/O ±18V/36V 8Pin PDIP N | |||
LT1219CN8#PBF Analog Devices | 397 ₽ | ||
LT1219CN8 Linear Technology | 445 ₽ | ||
LT1219CN8 Analog Devices | 5 349 ₽ | ||
LT1219CN8 Linear Technology | по запросу |
Производитель: Linear Technology
Описание: ИС, OP усилитель, PREC, DIP8, 1219
LT1218/LT1219 Precision Rail-to-Rail Input and Output Op Amps
FEATURES
s s s s s s
DESCRIPTION
The LT ®1218/LT1219 are bipolar op amps which combine rail-to-rail input and output operation with precision specifications.
Unlike other rail-to-rail amplifiers, the LT1218/ LT1219's input offset voltage is a low 90µV across the entire rail-to-rail input range, not just a portion of it. Using a patented technique, both input stages of the LT1218/ LT1219 are trimmed: one at the negative supply and the other at the positive supply. The resulting common mode rejection of 97dB minimum is much better than other railto-rail input op amps. A minimum open-loop gain of 500V/mV into a 10k load virtually eliminates all gain error. The LT1218 has conventional compensation which assures stability for capacitive loads of 1000pF or less. The LT1219 has compensation that requires the use of a 0.1µF output capacitor, which improves the amplifier's supply rejection and reduces output impedance at high frequ
- Тип ОУ: Precision
- Количество усилителей: 1
- Полоса частот: 0.15 МГц
- Slew Rate: 0.05 В/мкс
- Диапазон напряжения питания: 2 В ... ± 15 В
- Amplifier Case Style: DIP
- Количество выводов: 8
- SVHC: No SVHC (15-Dec-2010)
- Тип корпуса: DIP
- Тип усилителя: Precision
- Семейство: 1219
- Gain Bandwidth: 0.15 МГц
- Вход / выход: Rail-Rail I/O
- Input Offset Voltage Max: 0.09 мВ
- Рабочий диапазон температрур: -40°C ... +85°C
- Напряжение питания номинальное: 18 В
- Способ монтажа: Through Hole
Дополнительные аксессуары:
- HARWIN - D2608-42
- Multicomp - 2227MC-08-03-18-F1
- STANNOL - 631954
