Datasheet LT1206CN8 - Linear Technology Даташит Operational Amplifier (Op-Amp) ИС — Даташит
Linear Technology LT1206CN8
Наименование модели: LT1206CN8
32 предложений от 19 поставщиков
LT1206CN8#PBF
283 ₽
LT1206CN8
317 ₽
LT1206CN8
337 ₽
LT1206CN8
Производитель: Linear Technology
Описание: Operational Amplifier (Op-Amp) ИС
data sheetСкачать Data Sheet
LT1206 250mA/60MHz Current Feedback Amplifier FEATURES
DESCRIPTION
The LT®1206 is a current feedback amplifier with high output current drive capability and excellent video characteristics.
The LT1206 is stable with large capacitive loads, and can easily supply the large currents required by the capacitive loading. A shutdown feature switches the device into a high impedance, low current mode, reducing dissipation when the device is not in use. For lower bandwidth applications, the supply current can be reduced with a single external resistor. The low differential gain and phase, wide bandwidth, and the 250mA minimum output current drive make the LT1206 well suited to drive multiple cables in video systems. The LT1206 is manufactured on Linear Technology's proprietary complementary bipolar process.
, LT, LTC and LTM are registered trademarks of Linear Technology Corporation. All other trademarks are the property of their respective owners.
250mA Minimum Output Drive Curren
  • Тип ОУ: Current Feedback
  • Количество усилителей: 1
  • Полоса частот: 60 МГц
  • Slew Rate: 900 В/мкс
  • Диапазон напряжения питания: ± 5 В ... ± 15 В
  • Amplifier Case Style: DIP
  • Количество выводов: 8
На английском языке: Datasheet LT1206CN8 - Linear Technology Operational Amplifier (Op-Amp) IC
