Datasheet ISL28273FAZ - Intersil Даташит ИС, INST-AMP DUAL/QUAD RRIO, QSOP16 — Даташит
Наименование модели: ISL28273FAZ
![]() 14 предложений от 13 поставщиков IC OPAMP INSTR 265KHZ RRO 16QSOP / INST Amp Dual R-R I/O 5.5V 16-Pin QSOP T/R | |||
ISL28273FAZ-T7 Intersil | от 183 ₽ | ||
ISL28273FAZ Intersil | 186 ₽ | ||
ISL28273FAZ Xicor | 287 ₽ | ||
ISL28273FAZ-T7 Renesas | по запросу |
Производитель: Intersil
Описание: ИС, INST-AMP DUAL/QUAD RRIO, QSOP16
ISL28270, ISL28273, ISL28470
Data Sheet October 21, 2009 FN6260.6
Dual and Quad Channel Micropower, Single Supply, Rail-to-Rail Input and Output (RRIO) Instrumentation Amplifiers
The ISL28270 and ISL28273 are dual channel micropower instrumentation amplifiers (in-amps) and the ISL28470 is a quad channel in-amp optimized for single supply operation over the +2.4V to +5.5V range.
All three devices feature an Input Range Enhancement Circuit (IREC) which maintains CMRR performance for input voltages equal to the positive supply and down to 50mV above the negative supply rail. The input signal is capable of swinging above the positive supply rail and to 10mV above the negative supply with only a slight degradation of the CMRR performance. The output operation is rail-to-rail. The ISL28273 is compensated for a minimum gain of 10 or more. For higher gain applications, the ISL28270 and ISL28470 are compensated for a minimum gain of 100. The in-amps have bipolar input devices for best offse
- Количество усилителей: 2
- Input Offset Voltage: 600 мкВ
- Gain dB Min: 10 дБ
- Gain dB Max: 10 дБ
- Полоса частот: 265 кГц
- CMRR: 110 дБ
- Slew Rate: 0.6 В/мкс
- Диапазон напряжения питания: 2.4 В ... 5.5 В
- Ток потребления: 78 мкА
- Amplifier Case Style: QSOP
- Количество выводов: 16
- SVHC: No SVHC (15-Dec-2010)
- Тип корпуса: QSOP
- Тип усилителя: Rail - Rail Input / Output (RRIO)
- Семейство: 28273
- Gain Bandwidth: 10 МГц
- Input Offset Voltage Max: 600 мкВ
- Рабочий диапазон температрур: -40°C ... +125°C
- Напряжение питания номинальное: 5.5 В
- Способ монтажа: SMD
Дополнительные аксессуары:
- Dow Corning - 2265931
- Roth Elektronik - RE932-04
