Datasheet LT1789CS8-10 - Linear Technology Даташит ИС, INSTRUMENT усилитель, 25 кГц, 123 дБ, SOIC-8 — Даташит
Наименование модели: LT1789CS8-10
Купить LT1789CS8-10 на РадиоЛоцман.Цены — от 301 до 1 272 ₽ 39 предложений от 22 поставщиков Интегральные микросхемы Аналоговая техника — усилители — инструменты, ОУ (операционные), буферные | |||
LT1789CS8-10#PBF Analog Devices | 301 ₽ | ||
LT1789CS8-10#TRPBF Linear Technology | 309 ₽ | ||
LT1789CS8-10#TRPBF Analog Devices | по запросу | ||
LT1789CS8-10#PBF | по запросу |
Производитель: Linear Technology
Описание: ИС, INSTRUMENT усилитель, 25 кГц, 123 дБ, SOIC-8
LT1789-1/LT1789-10 Micropower, Single Supply Rail-to-Rail Output Instrumentation Amplifiers FEATURES
n n n n
DESCRIPTION
The LT®1789-1/LT1789-10 are micropower, precision instrumentation amplifiers that are optimized for single supply operation from 2.2V to 36V.
The quiescent current is 95A max, the inputs common mode to ground and the output swings within 110mV of ground. The gain is set with a single external resistor for a gain range of 1 to 1000 for the LT1789-1 and 10 to 1000 for the LT1789-10. The high accuracy of the LT1789-1 (40ppm maximum nonlinearity and 0.25% max gain error) is unmatched by other micropower instrumentation amplifiers. The LT1789-10 maximizes both the input common mode range and dynamic output range when an amplification of 10 or greater is required, allowing precise signal processing where other instrumentation amplifiers fail to operate. The LT1789-1/LT1789-10 are laser trimmed for very low input offset voltage, low input offset voltage drift, high CMRR an
- Количество усилителей: 1
- Input Offset Voltage: 235 мкВ
- Gain Min, dB: 10 дБ
- Gain Max, dB: 1000 дБ
- Полоса частот: 25 МГц
- Тип выхода: Single Ended
- CMRR: 123 дБ
- Slew Rate: 0.062 В/мкс
LT1789CS810, LT1789CS8 10
