Datasheet LT6402IUD-6 - Linear Technology Даташит усилитель, дифференциальный, DC-0.3GHZ, SMD — Даташит
Наименование модели: LT6402IUD-6
Купить LT6402IUD-6 на РадиоЛоцман.Цены — от 263 до 2 157 ₽ 23 предложений от 19 поставщиков High Speed Operational Amplifiers 300mhz Low distortion, Low noise, Diff Amplifier/ADC Driver | |||
LT6402IUD-6#PBF Analog Devices | 263 ₽ | ||
LT6402IUD-6#TRPBF Linear Technology | 314 ₽ | ||
LT6402IUD-6#PBF Analog Devices | от 435 ₽ | ||
LT6402IUD-6#PBF Analog Devices | по запросу |
Производитель: Linear Technology
Описание: Усилитель, дифференциальный, DC-0.3GHZ, SMD
FEATURES
LT6402-6 300MHz Low Distortion, Low Noise Differential Amplifier/ ADC Driver (AV = 6dB) DESCRIPTIO
The LT®6402-6 is a low distortion, low noise differential amplifier/ADC driver for use in applications from DC to 300MHz.
The LT6402-6 has been designed for ease of use, with minimal support circuitry required. Exceptionally low input-referred noise and low distortion (with either single-ended or differential inputs) make the LT6402-6 an excellent solution for driving high speed 12-bit and 14-bit ADCs. In addition to the normal unfiltered outputs (+OUT and OUT), the LT6402-6 has a built-in 75MHz differential low pass filter and an additional pair of filtered outputs (+OUTFILTERED, OUTFILTERED) to reduce external filtering components when driving high speed ADCs. The output common mode voltage is easily set via the VOCM pin, eliminating an output transformer or AC-coupling capacitors in many applications. The LT6402-6 is designed to meet the demanding requirements of communi
- Количество усилителей: 1
- Input Offset Voltage: 6.5 мВ
- Gain dB Max: 6.3 дБ
- Полоса частот: 300 МГц
- Slew Rate: 400 В/мкс
- Диапазон напряжения питания: 4 В ... 5.5 В
- Ток потребления: 30 мА
- Amplifier Case Style: QFN
- Количество выводов: 16
- SVHC: No SVHC (15-Dec-2010)
- Тип корпуса: QFN
- Тип усилителя: Low Noise, Low Distortion
- Семейство: 6402
- Input Offset Voltage Max: 10 мВ
- Рабочий диапазон температрур: -40°C ... +85°C
- Напряжение питания номинальное: 5.5 В
- Способ монтажа: SMD
LT6402IUD6, LT6402IUD 6
