Datasheet SP4-L2-DC48V - Panasonic Даташит Мощное реле, 48 В постоянный ток, 10 А, 4PDT, PLUG-IN — Даташит
Наименование модели: SP4-L2-DC48V
Купить SP4-L2-DC48V на РадиоЛоцман.Цены — от 3 590 до 343 852 ₽ 16 предложений от 7 поставщиков Реле электромагнитные Силовые реле, более 2 А | |||
SP4-L2-DC48V Panasonic | 3 590 ₽ | ||
SP4-L2-DC48V Panasonic | от 6 229 ₽ | ||
SP4-L2-DC48V Panasonic | от 7 026 ₽ | ||
SP4-L2-DC48V Panasonic | по запросу |
Производитель: Panasonic
Описание: Мощное реле, 48 В постоянный ток, 10 А, 4PDT, PLUG-IN
SP
2c 15A, 4c 10A polarized power relays
SP RELAYS
FEATURES
1.
Small, slim form factor Facilitating the form factor reduction of devices, the overall height of the relay package is less than half that of our HP relay. 2. High sensitivity The high-efficiency polarized electromagnetic mechanism in conjunction with our exclusive spring alignment method achieves levels of sensitivity higher than relays that have been available up to now. For both the 2 Form C and 4 Form C single side stable and 2 coil latching types, the 150 mW minimum operating power level allows direct driving by transistor or chip controllers. 3. High reliability and long life With a structure that ensures almost perfectly complete twin contact and minimal contact bounce, you get greater reliability than has so far been provided by power relays. 4. Latching types also available 1 coil latching and 2 coil latching types are available. In cases where it was formerly unavoidable to use plural relays for large power memory
- Тип реле: Polarized
- Coil Voltage VDC Nom: 48 В
- Contact Current Max: 10 А
- Contact Voltage AC Nom: 250 В
- Contact Voltage DC Nom: 30 В
- Coil Resistance: 7.68 кОм
- Конфигурация контактов: 4PDT
SP4L2DC48V, SP4 L2 DC48V
