Datasheet JM1AN-ZTM-DC12V-F - Panasonic Даташит Мощное реле, 12 В постоянный ток, 20 А, SPST-NO, под винт — Даташит
Наименование модели: JM1AN-ZTM-DC12V-F
5 предложений от 5 поставщиков
RELAY GEN PURPOSE SPST 20A 12V / General Purpose Relay SPST-NO (1 Form A) 12VDC Coil Chassis Mount
JM1AN-ZTM-DC12V-F
Panasonic
396 ₽
JM1AN-ZTM-DC12V-F
Panasonic
420 ₽
LIXINC Electronics
JM1AN-ZTM-DC12V-F
Panasonic
HXD Co.
JM1AN-ZTM-DC12V-F
Panasonic
Производитель: Panasonic
Описание: Мощное реле, 12 В постоянный ток, 20 А, SPST-NO, под винт
data sheetСкачать Data Sheet
JM
Ideal for compressor and motor control Inrush 80A, 1a 20A power relay
VDE
JM RELAYS
· Conforms to the various safety standards UL, CSA, VDE available · The line up can support economical mounting methods.
The relay are equipped with a drive terminal (coil terminal) on one side for PCBs, and a load terminal (tab terminal #250) on the reverse side. The line up includes the TM type which can be attached directly to the PCB composing a drive circuit, and the TMP type which supports economical wiring. The TMP type can also be directly attached, and a high capacity load can be wired to the tab terminal.
  • Тип реле: Power
  • Coil Voltage VDC Nom: 12 В
  • Contact Current Max: 20 А
  • Contact Voltage AC Nom: 250 В
  • Contact Voltage DC Nom: 5 В
  • Coil Resistance: 160 Ом
  • Конфигурация контактов: SPST-NO
  • Coil Type: DC
JM1ANZTMDC12VF, JM1AN ZTM DC12V F
На английском языке: Datasheet JM1AN-ZTM-DC12V-F - Panasonic POWER RELAY, 12 V DC, 20 A, SPST-NO, PANEL
