Datasheet HL1-HTM-DC24V-F - Panasonic Даташит Мощное реле, 24 В постоянный ток, 15 А, SPDT, под винт — Даташит
Наименование модели: HL1-HTM-DC24V-F
Купить HL1-HTM-DC24V-F на РадиоЛоцман.Цены — от 74 до 786 ₽ 7 предложений от 7 поставщиков Electromechanical Relay 24VDC 650Ω 15A SPDT( (43mm 20.6mm 40.75mm)) Top Flange General Purpose Relay Automotive | |||
HL1-HTM-DC24V-F Panasonic | 74 ₽ | ||
HL1-HTM-DC24V-F Panasonic | 739 ₽ | ||
HL1-HTM-DC24V-F Panasonic | по запросу | ||
HL1-HTM-DC24V-F | по запросу |
Производитель: Panasonic
Описание: Мощное реле, 24 В постоянный ток, 15 А, SPDT, под винт
HL
15A (1C), 10 A (2C) SPACE SAVING POWER RELAY
HL RELAYS
TYPICAL APPLICATIONS
Suitable for factory automation equipment and automotive devices 1.
Control panels, power supply equipment, molding equipment, machine tools, welding equipment, agricultural equipment, etc. 2. Office equipment, automatic vending machines, telecommunications equipment, disaster prevention equipment, copiers, measuring devices, medical equipment, amusement devices, etc. 3. All types of household appliance About Cd-free contacts We have introduced Cadmium free type products to reduce Environmental Hazardous Substances. (The suffix "F" should be added to the part number.) Please replace parts containing Cadmium with Cadmium-free products and evaluate them with your actual application before use because the life of a relay depends on the contact material and load.
- Тип реле: Power
- Coil Voltage VDC Nom: 24 В
- Contact Current Max: 15 А
- Contact Voltage AC Nom: 250 В
- Contact Voltage DC Nom: 5 В
- Coil Resistance: 650 Ом
- Конфигурация контактов: SPDT
- Coil Type: DC
HL1HTMDC24VF, HL1 HTM DC24V F
