Datasheet Texas Instruments LM2903DGKR — Даташит
Серия | LM2903 |
Модель | LM2903DGKR |
Двойной дифференциальный компаратор 8-VSSOP от -40 до 125
Datasheet LM193, LM293, LM293A, LM393, LM393A, LM2903, LM2903V
PDF, 1.6 Мб, Версия: Y, Файл опубликован: 30 июн 2015, Страниц: 37
Dual Differential Comparators
![]() 62 предложений от 27 поставщиков Интегральные микросхемы Линейные микросхемы - Компараторы | |||
LM2903DGKR Texas Instruments | 5.23 ₽ | ||
LM2903DGKR LAPIS Semiconductor | от 6.05 ₽ | ||
LM2903DGKR Texas Instruments | от 14 ₽ | ||
LM2903DGKR Rohm | от 18 ₽ |
Pin | 8 | 8 | 8 |
Package Type | DGK | DGK | DGK |
Industry STD Term | VSSOP | VSSOP | VSSOP |
JEDEC Code | R-PDSO-G | R-PDSO-G | R-PDSO-G |
Package QTY | 2500 | 2500 | 2500 |
Carrier | LARGE T&R | LARGE T&R | LARGE T&R |
Маркировка | MAS | MAP | MAU |
Width (мм) | 3 | 3 | 3 |
Length (мм) | 3 | 3 | 3 |
Thickness (мм) | .97 | .97 | .97 |
Pitch (мм) | .65 | .65 | .65 |
Max Height (мм) | 1.07 | 1.07 | 1.07 |
Input Bias Current (+/-)(Max) | 50 нА |
Iq per channel(Max) | 0.5 мА |
Количество каналов | 2 |
Тип выхода | Open Collector |
Package Group | VSSOP |
Package Size: mm2:W x L | 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) PKG |
Propagation Delay Time | 1.3 uS |
Rail-to-Rail | Out |
Rating | Catalog |
Special Features | N/A |
VICR(Max) | 28.5 В |
Vos (Offset Voltage @ 25C)(Max) | 7 мВ |
Vs(Max) | 30 В |
Vs(Min) | 2 В |
- Designing Overcurrent protection for TPL7407L Peripheral DriverPDF, 177 Кб, Файл опубликован: 5 ноя 2014
Microcontroller units (MCUs) are generally limited with lower drive on the I/Os. Most of the applicationsrequiring MCU boards to drive high-current loads need discrete implementation and additional components which use a lot of board space. This board space is called a peripheral driver section. The TPL7407L device is an integrated peripheral driver with seven channel drivers inside. The TPL740
Серия: LM2903 (24)
- Semiconductors > Amplifiers > Comparators
