Datasheet LM293H - National Semiconductor Даташит компаратор DUAL КМОП, TO-5-8, 293 — Даташит
Наименование модели: LM293H
Купить LM293H на РадиоЛоцман.Цены — от 445 до 2 783 ₽ 27 предложений от 18 поставщиков Интегральные микросхемы Линейные микросхемы - Компараторы | |||
LM293H/NOPB Texas Instruments | 445 ₽ | ||
LM293H Texas Instruments | 519 ₽ | ||
LM293H Texas Instruments | от 664 ₽ | ||
LM293H/883 Texas Instruments | по запросу |
Описание: Компаратор DUAL КМОП, TO-5-8, 293
LM193 LM293 LM393 LM2903 Low Power Low Offset Voltage Dual Comparators
January 1995
General Description
The LM193 series consists of two independent precision voltage comparators with an offset voltage specification as low as 2 0 mV max for two comparators which were designed specifically to operate from a single power supply over a wide range of voltages Operation from split power supplies is also possible and the low power supply current drain is independent of the magnitude of the power supply voltage These comparators also have a unique characteristic in that the input common-mode voltage range includes ground even though operated from a single power supply voltage Application areas include limit comparators simple analog to digital converters pulse squarewave and time delay generators wide range VCO MOS clock timers multivibrators and high voltage digital logic gates The LM193 series was designed to directly
- Время отклика: 1300 нс
- Количество выводов: 8
- SVHC: No SVHC (15-Dec-2010)
- Тип корпуса: TO-5
- Семейство: 293
- Особенности компаратора: Dual low Power CMOS
- IC Generic Number: 293
- Количество логических функций: 293
- Количество компараторов: 2
- Рабочий диапазон температрур: -25°C ...
+85°C
