Datasheet LT1714CGN - Linear Technology Даташит High Speed компаратор ИС — Даташит
Наименование модели: LT1714CGN
![]() 47 предложений от 22 поставщиков Интегральные микросхемы Линейные микросхемы - Компараторы | |||
LT1714CGN Linear Technology | 254 ₽ | ||
LT1714CGN#TRPBF Analog Devices | от 443 ₽ | ||
LT1714CGN Analog Devices | 965 ₽ | ||
LT1714CGN#TRPBF Analog Devices | по запросу |
Производитель: Linear Technology
Описание: High Speed компаратор ИС
FEATURES
s s s
LT1713/LT1714 Single/Dual, 7ns, Low Power, 3V/5V/±5V Rail-to-Rail Comparators DESCRIPTIO
The LT®1713/LT1714 are UltraFastTM 7ns, single/dual comparators featuring rail-to-rail inputs, rail-to-rail complementary outputs and an output latch.
Optimized for 3V and 5V power supplies, they operate over a single supply voltage range from 2.4V to 12V or from ±2.4V to ±6V dual supplies. The LT1713/LT1714 are designed for ease of use in a variety of systems. In addition to wide supply voltage flexibility, rail-to-rail input common mode range extends 100mV beyond both supply rails and the outputs are protected against phase reversal for inputs extending further beyond the rails. Also, the rail-to-rail inputs may be taken to opposite rails with no significant increase in input current. The rail-to-rail matched complementary outputs interface directly to TTL or CMOS logic and can sink 10mA to within 0.5V of GND or source 10mA to within 0.7V of V +. The LT1713/LT1714 have internal TT
- Тип компаратора: High Speed
- Количество компараторов: 2
- Время отклика: 7 нс
- Тип выхода: TTL/CMOS Compatible
- Ток потребления: 5.5 мА
- Диапазон напряжения питания: ± 2.4 В ... ± 6 В
- Amplifier Case Style: SSOP
- Количество выводов: 16
