Datasheet LMC7211BIM/NOPB - National Semiconductor Даташит ИС, MICROPOWER COMP, SINGLE, 4 мкс, SOIC-8 — Даташит
Наименование модели: LMC7211BIM/NOPB
Купить LMC7211BIM/NOPB на РадиоЛоцман.Цены — от 45 до 250 ₽ 33 предложений от 16 поставщиков Компаратор малогабаритный уровень выхода до напряжения питания КМОП | |||
LMC7211BIM/NOPB Texas Instruments | 45 ₽ | ||
LMC7211BIM/NOPB Texas Instruments | 61 ₽ | ||
LMC7211BIM/NOPB Texas Instruments | 70 ₽ | ||
LMC7211BIM/NOPB STMicroelectronics | по запросу |
Описание: ИС, MICROPOWER COMP, SINGLE, 4 мкс, SOIC-8
LMC7211 Tiny CMOS Comparator with Rail-to-Rail Input and Push-Pull Output
January 26, 2010
LMC7211 Tiny CMOS Comparator with Rail-to-Rail Input and PushPull Output
General Description
The LMC7211 is a micropower CMOS comparator available in the space saving SOT23-5 package.
This makes the comparator ideal for space and weight critical designs. The LMC7211 is supplied in two offset voltage grades, 5 mV and 15 mV. The main benefits of the Tiny package are most apparent in small portable electronic devices, such as mobile phones, pagers, notebook computers, personal digital assistants, and PCMCIA cards. The rail-to-rail input voltage makes the LMC7211 a good choice for sensor interfacing, such as light detector circuits, optical and magnetic sensors, and alarm and status circuits. The Tiny Comparator's outside dimensions (length x width x height) of 3.05mm x 3.00mm x 1.43mm allow it to fit into tight spaces on PC boards. See the LMC7221 for a comparator with an open-drain output.
- Тип компаратора: General Purpose
- Количество компараторов: 1
- Время отклика: 4 мкс
- Тип выхода: Push-Pull
- Ток потребления: 14 мкА
- Диапазон напряжения питания: 2.7 В ... 15 В
- Amplifier Case Style: SOIC
