Datasheet LM339MX/NOPB - National Semiconductor Даташит ИС, PRECISION COMP, QUAD, 1.3 мкс, SOIC-14 — Даташит
Наименование модели: LM339MX/NOPB
Купить LM339MX/NOPB на РадиоЛоцман.Цены — от 23 до 7 104 ₽ 40 предложений от 20 поставщиков TEXAS INSTRUMENTS LM339MX/NOPB Analogue Comparator, Quad, Low Power, 4, 1.3µs, 2V to 36V, ± 1V to ± 18V, SOIC, 14Pins | |||
LM339MX/NOPB Texas Instruments | 23 ₽ | ||
LM339MX/NOPB Texas Instruments | 36 ₽ | ||
LM339MX/NOPB Texas Instruments | от 103 ₽ | ||
LM339MX/NOPB Texas Instruments | от 145 ₽ |
Описание: ИС, PRECISION COMP, QUAD, 1.3 мкс, SOIC-14
LM139/LM239/LM339/LM2901/LM3302 Low Power Low Offset Voltage Quad Comparators
March 2004
General Description
The LM139 series consists of four independent precision voltage comparators with an offset voltage specification as low as 2 mV max for all four comparators.
These were designed specifically to operate from a single power supply over a wide range of voltages. Operation from split power supplies is also possible and the low power supply current drain is independent of the magnitude of the power supply voltage. These comparators also have a unique characteristic in that the input common-mode voltage range includes ground, even though operated from a single power supply voltage. Application areas include limit comparators, simple analog to digital converters; pulse, squarewave and time delay generators; wide range VCO; MOS clock timers; multivibrators and high voltage digital logic gates. The LM139 seri
- Тип компаратора: Precision
- Количество компараторов: 4
- Время отклика: 1.3 мкс
- Ток потребления: 800 мкА
- Диапазон напряжения питания: ± 1 В ... ± 18 В
- Amplifier Case Style: SOIC
- Количество выводов: 14
