Datasheet LM319N/NOPB - National Semiconductor Даташит ИС, HIGH SPEED COMP, DUAL, 80 нс, DIP-14 — Даташит
Наименование модели: LM319N/NOPB
Купить LM319N/NOPB на РадиоЛоцман.Цены — от 63 до 459 ₽ 42 предложений от 17 поставщиков Интегральные микросхемы Линейные микросхемы - Компараторы | |||
LM319N/NOPB Texas Instruments | 63 ₽ | ||
LM319N/NOPB National Semiconductor | 117 ₽ | ||
LM319N/NOPB National Semiconductor | 139 ₽ | ||
LM319N/NOPB Texas Instruments | от 311 ₽ |
Описание: ИС, HIGH SPEED COMP, DUAL, 80 нс, DIP-14
LM119/LM219/LM319 High Speed Dual Comparator
August 2000
General Description
The LM119 series are precision high speed dual comparators fabricated on a single monolithic chip.
They are designed to operate over a wide range of supply voltages down to a single 5V logic supply and ground. Further, they have higher gain and lower input currents than devices like the LM710. The uncommitted collector of the output stage makes the LM119 compatible with RTL, DTL and TTL as well as capable of driving lamps and relays at currents up to 25 mA. The LM319A offers improved precision over the standard LM319, with tighter tolerances on offset voltage, offset current, and voltage gain. Although designed primarily for applications requiring operation from digital logic supplies, the LM119 series are fully specified for power supplies up to ± 15V. It features faster response than the LM111 at the expense of higher power dissipation. However, the high speed,
- Тип компаратора: High Speed
- Количество компараторов: 2
- Время отклика: 80 нс
- Тип выхода: DTL, RTL, TTL
- Ток потребления: 4.3 мА
- Диапазон напряжения питания: 5 В ... 36 В
- Amplifier Case Style: DIP
