Популярные микроконтроллеры Nuvoton серий М2354 и М251 со склада компании Смарт-ЭК
Datasheet LM2901MX/NOPB - National Semiconductor Даташит ИС, PRECISION COMP, QUAD, 1.3 мкс, SOIC-14 — Даташит
National Semiconductor LM2901MX/NOPB
Наименование модели: LM2901MX/NOPB
59 предложений от 25 поставщиков
Аналоговый компаратор, Точное Напряжение, 4 Компаратора, 1.3 мкс, 2В до 36В, ±1В до ± 18В, SOIC
LM2901MX/NOPB
от 22 ₽
LM2901MX/NOPB
22 ₽
LM2901MX/NOPB
от 125 ₽
LM2901MX/NOPB
162 ₽
Описание: ИС, PRECISION COMP, QUAD, 1.3 мкс, SOIC-14
data sheetСкачать Data Sheet
LM139/LM239/LM339/LM2901/LM3302 Low Power Low Offset Voltage Quad Comparators
March 2004
General Description
The LM139 series consists of four independent precision voltage comparators with an offset voltage specification as low as 2 mV max for all four comparators.
These were designed specifically to operate from a single power supply over a wide range of voltages. Operation from split power supplies is also possible and the low power supply current drain is independent of the magnitude of the power supply voltage. These comparators also have a unique characteristic in that the input common-mode voltage range includes ground, even though operated from a single power supply voltage. Application areas include limit comparators, simple analog to digital converters; pulse, squarewave and time delay generators; wide range VCO; MOS clock timers; multivibrators and high voltage digital logic gates. The LM139 seri
  • Тип компаратора: General Purpose
  • Количество компараторов: 4
  • Время отклика: 1.3 мкс
  • Тип выхода: CMOS, MOS, TTL, DTL, ECL
  • Ток потребления: 800 мкА
  • Диапазон напряжения питания: ± 1 В ... ± 18 В
На английском языке: Datasheet LM2901MX/NOPB - National Semiconductor IC, PRECISION COMP, QUAD, 1.3 µs, SOIC-14
