Datasheet LMH6704MF - National Semiconductor Даташит BUFFER, PROGRAMMABLE, 6704, SOT-23-6 — Даташит
National Semiconductor LMH6704MF
Наименование модели: LMH6704MF
33 предложений от 17 поставщиков
LIXINC Electronics
LMH6704MF/NOPB
от 45 ₽
LMH6704MF
80 ₽
TradeElectronics
LMH6704MF
Allelco
LMH6704MF
Описание: BUFFER, PROGRAMMABLE, 6704, SOT-23-6
data sheetСкачать Data Sheet
LMH6704 650 MHz Programmable Gain Buffer with Disable
May 2005
General Description
The LMHTM6704 is a very wideband, DC coupled programmable gain buffer designed specifically for wide dynamic range systems requiring exceptional signal fidelity.
The LMH6704 includes on chip feedback and gain set resistors, simplifying PCB layout while providing user programmable gains of +1, +2 and -1 V/V. The LMH6704 provides a disable pin, which places the amplifier in a high output impedance, low power mode. The Disable pin may be allowed to float high. With a 650 MHz Small Signal Bandwidth (AV = +1), full power gain flatness to 200 MHz, and excellent Differential Gain and Phase, the LMH6704 is optimized for video applications. High resolution video systems will benefit from the LMH6704's ability to drive multiple video loads at low levels of differential gain or differential phase distortion. The LMH6704 is constructed with National's proprieta
  • Number of Amplifiers: 1
  • Gain Bandwidth: 650 МГц
  • Slew Rate: 3000 В/мкс
  • Диапазон напряжения питания: ± 4 В ... ± 6 В
  • Выходной ток: 90 мА
  • Amplifier Output: Single Ended
  • Amplifier Case Style: SOT-23
  • Количество выводов: 6
  • SVHC: No SVHC (15-Dec-2010)
  • Тип корпуса: SOT-23
  • Amplifier Type: Programmable Gain
  • Полоса частот: 650 МГц
  • Семейство: 6704
  • IC Generic Number: 6704
  • Input Offset Voltage Max: 8.3 мВ
  • Количество логических функций: 6704
  • Рабочий диапазон температрур: -40°C ... +85°C
  • Output Current Max: 90 мА
  • Output Type: Single Ended
  • Напряжение питания номинальное: 6 В
  • Способ монтажа: SMD
На английском языке: Datasheet LMH6704MF - National Semiconductor BUFFER, PROGRAMMABLE, 6704, SOT-23-6
