Datasheet LM4950TA - National Semiconductor Даташит усилитель, 3 Вт STEREO/6W MONO, 4950, TO-220 — Даташит
Наименование модели: LM4950TA
![]() 14 предложений от 14 поставщиков Микросхема Усилитель звуковой частоты, Audio Amp Speaker 1CH Mono/2CH Stereo 7.5W Class-AB 9Pin(9+Tab) TO-220 Rail | |||
LM4950TA/NOPB Texas Instruments | 68 ₽ | ||
LM4950TA/NOPB National Semiconductor | 169 ₽ | ||
LM4950TA/NOPB Texas Instruments | 241 ₽ | ||
LM4950TA/NOPB Texas Instruments | по запросу |
Описание: Усилитель, 3 Вт STEREO/6W MONO, 4950, TO-220
LM4950 7.5W Mono-BTL or 3.1W Stereo Audio Power Amplifier
August 2004
General Description
The LM4950 is a dual audio power amplifier primarily designed for demanding applications in flat panel monitors and TV's.
It is capable of delivering 3.1 watts per channel to a 4 single-ended load with less than 1% THD+N or 7.5 watts mono BTL to an 8 load, with less than 10% THD+N from a 12VDC power supply. Boomer audio power amplifiers were designed specifically to provide high quality output power with a minimal amount of external components. The LM4950 does not require bootstrap capacitors or snubber circuits. Therefore, it is ideally suited for display applications requiring high power and minimal size. The LM4950 features a low-power consumption active-low shutdown mode. Additionally, the LM4950 features an internal thermal shutdown protection mechanism along with short circuit protection. The LM4950 contains advanced pop & click cir
- Количество каналов: 2
- Output Power: 7.5 Вт
- Количество выводов: 9
- SVHC: No SVHC (15-Dec-2010)
- Тип корпуса: TO-220
- Amplifier Type: Power
- Bandwidth: 20 кГц
- Семейство: 4950
- IC Generic Number: 4950
- Load Impedance Min: 4 Ом
- Number of Amplifiers: 2
- Рабочий диапазон температрур: -40°C ... +85°C
- Power Rating RMS: 7.5 Вт
- Supply Voltage + Nom: 16 В
- Способ монтажа: Through Hole
- Диапазон напряжения питания: 9.6 В ... 16 В
