Популярные микроконтроллеры Nuvoton серий М2354 и М251 со склада компании Смарт-ЭК
Datasheet LME49725MA - National Semiconductor Даташит ИС, аудио OP усилитель, DUAL, 4.5 В, 8SOIC — Даташит
National Semiconductor LME49725MA
Наименование модели: LME49725MA
Микросхема Операционный усилитель, PowerWise( ) Dual High Performance, High Fidelity Audio Operational Amplifier 8-SOIC -40℃ to 85℃
LME49725MA/NOPB
56 ₽
LME49725MA/NOPB
101 ₽
IC Home
LME49725MA/NOPB
LifeElectronics
LME49725MA/NOPB
Описание: ИС, аудио OP усилитель, DUAL, 4.5 В, 8SOIC
data sheetСкачать Data Sheet
LME49725 PowerWise® Dual High Performance, High Fidelity Audio Operational Amplifier
April 3, 2008
General Description
The LME49725 is part of the ultra-low distortion, low noise, high slew rate operational amplifier series optimized and fully specified for high performance, high fidelity applications.
Combining advanced leading-edge process technology with state-of-the-art circuit design, the LME49725 audio operational amplifiers deliver superior audio signal amplification for outstanding audio performance. The LME49725 combines extremely low voltage noise density (3.3nV/Hz) with vanishingly low THD+N (0.00004%) to easily satisfy the most demanding audio applications. To ensure that the most challenging loads are driven without compromise, the LME49725 has a high slew rate of ±15V/s and an output current capability of ±22mA. Further, dynamic range is maximized by an output stage that drives 2k loads
  • Количество каналов: 2
  • Диапазон напряжения питания: ± 4.5 В ... ± 18 В
  • THD + N: 0.00004% @ 600 Ом, VDD=15V
  • Load Impedance: 600 Ом
  • Amplifier Case Style: SOIC
  • Количество выводов: 8
  • SVHC: No SVHC (15-Dec-2010)
  • Тип корпуса: NSOIC
  • Amplifier Type: Operational
  • Семейство: 49725
  • Gain Bandwidth: 40 МГц
  • Input Offset Voltage Max: 0.5 мВ
  • Load Impedance Min: 600 Ом
  • Number of Amplifiers: 2
  • Рабочий диапазон температрур: -40°C ... +85°C
  • Output Current + Max: 22 мА
  • Settling Time: 1.6µs
  • Slew Rate: 15 В/мкс
  • Supply Voltage + Nom: 18 В
  • Способ монтажа: SMD
  • Op Amp Type: Low Noise
На английском языке: Datasheet LME49725MA - National Semiconductor IC, AUDIO OP AMP, DUAL, 4.5 V, 8SOIC
