Datasheet LM4941SD - National Semiconductor Даташит усилитель, аудио POWER, CLASS AB, BUMP-9 — Даташит
Наименование модели: LM4941SD
![]() 33 предложений от 17 поставщиков Микросхема Усилитель звуковой частоты, TEXAS INSTRUMENTS LM4941SD/NOPB Audio Power Amplifier, AB, 1Channel, 1.25W, 2.4V to 5.5V, LLP, 8Pins | |||
LM4941SD/NOPB Texas Instruments | 29 ₽ | ||
LM4941SD/NOPB Texas Instruments | от 38 ₽ | ||
LM4941SD Texas Instruments | 108 ₽ | ||
LM4941SD Texas Instruments | по запросу |
Описание: Усилитель, аудио POWER, CLASS AB, BUMP-9
LM4941 1.25 Watt Fully Differential Audio Power Amplifier With RF Suppression and Shutdown
March 2007
General Description
The LM4941 is a fully differential audio power amplifier primarily designed for demanding applications in mobile phones and other portable communication device applications.
It is capable of delivering 1.25 watts of continuous average power to a 8 load with less than 1% distortion (THD+N) from a 5VDC power supply. The LM4941 does not require output coupling capacitors or bootstrap capacitors, and therefore is ideally suited for mobile phone and other small form factor applications where minimal PCB space is a primary requirement. The LM4941 also features proprietary internal circuitry that suppresses the coupling of RF signals into the chip. This is important because certain types of RF signals (such as GSM) can couple into audio amplifiers in such a way that part of the sig
- Количество каналов: 1
- Output Power: 1.25 Вт
- Количество выводов: 9
- SVHC: No SVHC (15-Dec-2010)
- Тип корпуса: Bump
- Amplifier Type: аудио
- Семейство: 4941
- Input Offset Voltage Max: 6 мВ
- Load Impedance Min: 8 Ом
- Number of Amplifiers: 1
- Рабочий диапазон температрур: -40°C ... +85°C
- Power Rating RMS: 1.25 Вт
- Supply Voltage + Nom: 6 В
- Способ монтажа: SMD
- Диапазон напряжения питания: 2.4 В ... 5.5 В
Дополнительные аксессуары:
- Electrolube - HTS35SL
