Datasheet LM4902MM - National Semiconductor Даташит усилитель, аудио CELLULAR, SMD, LLP-16 — Даташит
Наименование модели: LM4902MM
![]() 34 предложений от 19 поставщиков Микросхема Усилитель звуковой частоты, Audio Amp Speaker 1CH Mono 0.675W Class-AB 8Pin VSSOP T/R | |||
LM4902MM Rochester Electronics | от 6.98 ₽ | ||
LM4902MM Texas Instruments | 13 ₽ | ||
LM4902MM/NOPB Texas Instruments | 51 ₽ | ||
LM4902MM Texas Instruments | 97 ₽ |
Описание: Усилитель, аудио CELLULAR, SMD, LLP-16
LM4902 265mW at 3.3V Supply Audio Power Amplifier with Shutdown Mode
February 2002
General Description
The LM4902 is a bridged audio power amplifier capable of delivering 265mW of continuous average power into an 8 load with 1% THD+N from a 3.3V power supply.
Boomer ® audio power amplifiers were designed specifically to provide high quality output power from a low supply voltage while requiring a minimal amount of external components. Since the LM4902 does not require output coupling capacitors, bootstrap capacitors or snubber networks, it is optimally suited for low-power portable applications. The LM4902 features an externally controlled, low power consumption shutdown mode, and thermal shutdown protection. The closed loop response of the unity-gain stable LM4902 can be configured by external gain-setting resistors.
- Количество каналов: 1
- Output Power: 265 мВт
- Количество выводов: 8
- SVHC: No SVHC (15-Dec-2010)
- Тип корпуса: LLP
- Amplifier Type: Power
- Семейство: 4902
- Load Impedance Min: 8 Ом
- Number of Amplifiers: 2
- Рабочий диапазон температрур: -40°C ... +85°C
- Power Rating RMS: 675 мВт
- Supply Voltage + Nom: 6 В
- Способ монтажа: SMD
- Диапазон напряжения питания: 2 В ... 5.5 В
