Datasheet LM833N/NOPB - National Semiconductor Даташит ИС, аудио OP-AMP, 15 МГц, DIP-8 — Даташит
National Semiconductor LM833N/NOPB
Наименование модели: LM833N/NOPB
54 предложений от 24 поставщиков
LM833N/NOPB
от 10 ₽
LM833N/NOPB
25 ₽
LM833N/NOPB
140 ₽
LM833N/NOPB
Описание: ИС, аудио OP-AMP, 15 МГц, DIP-8
data sheetСкачать Data Sheet
LM833 Dual Audio Operational Amplifier
January 2003
General Description
The LM833 is a dual general purpose operational amplifier designed with particular emphasis on performance in audio systems.
This dual amplifier IC utilizes new circuit and processing techniques to deliver low noise, high speed and wide bandwidth without increasing external components or decreasing stability. The LM833 is internally compensated for all closed loop gains and is therefore optimized for all preamp and high level stages in PCM and HiFi systems. The LM833 is pin-for-pin compatible with industry standard dual operational amplifiers.
  • Количество каналов: 2
  • Диапазон напряжения питания: 10 В ... 36 В
  • Load Impedance: 2 кОм
  • Рабочий диапазон температрур: -40°C ... +85°C
  • Amplifier Case Style: DIP
  • Количество выводов: 8
  • Slew Rate: 7 В/мкс
На английском языке: Datasheet LM833N/NOPB - National Semiconductor IC, AUDIO OP-AMP, 15 MHz, DIP-8
