Datasheet LMV1012UP-25 - National Semiconductor Даташит Усилитель, микрофон, 25 дБ GAIN, SMD, 1013 — Даташит
Наименование модели: LMV1012UP-25
![]() 36 предложений от 17 поставщиков Микросхема Усилитель звуковой частоты, TEXAS INSTRUMENTS LMV1012UP-25/NOPB Audio Power Amplifier, 1Channel, 2V to 5V, BGA, 4Pins | |||
LMV1012UP-25/NOPB Texas Instruments | 29 ₽ | ||
LMV1012UP-25/NOPB Rochester Electronics | от 29 ₽ | ||
LMV1012UP-25/NOPB Texas Instruments | 42 ₽ | ||
LMV1012UP-25/NOPB Texas Instruments | от 94 ₽ |
Описание: Усилитель, микрофон, 25 дБ GAIN, SMD, 1013
LMV1012 Analog Series Pre-Amplified IC's for High Gain 2-Wire Microphones
August 2004
LMV1012 Analog Series: Pre-Amplified IC's for High Gain 2-Wire Microphones
General Description
The LMV1012 is an audio amplifier series for small form factor electret microphones.
This 2-wire portfolio is designed to replace the JFET amplifier currently being used. The LMV1012 series is ideally suited for applications requiring high signal integrity in the presence of ambient or RF noise, such as in cellular communications. The LMV1012 audio amplifiers are guaranteed to operate over a 2.2V to 5.0V supply voltage range with fixed gains of 7.8 dB, 15.6 dB, 20.9 dB, and 23.8 dB. The devices offer excellent THD, gain accuracy and temperature stability as compared to a JFET microphone. The LMV1012 series enables a two-pin electret microphone solution, which provides direct pin-to-pin compatibility with the existing JFET market. The devices are offered in extremely thin space saving 4-bump micro SMD packa
- Количество каналов: 1
- Диапазон напряжения питания: 2 В ... 5 В
- THD + N: 0.21% @ VDD=5V
- Load Impedance: 2.2 кОм
- Рабочий диапазон температрур: -40°C ... +85°C
- Тип корпуса: BGA
- Количество выводов: 4
- SVHC: No SVHC (19-Dec-2011)
- Тип усилителя: Power
- Семейство: 1012
- IC Generic Number: 1012
- Входной импеданс минимальный: 2200 Ом
- Количество усилителей: 1
- Напряжение питания (+) номинальное: 5 В
- Способ монтажа: SMD
LMV1012UP25, LMV1012UP 25
