Datasheet LME49721MA - National Semiconductor Даташит ИС, OP усилитель, 5 В, RRIO, SMD — Даташит
Наименование модели: LME49721MA
![]() 40 предложений от 19 поставщиков Интегральные микросхемы Аналоговая техника — усилители — инструменты, ОУ (операционные), буферные | |||
LME49721MA/NOPB Texas Instruments | от 24 ₽ | ||
LME49721MA/NOPB Texas Instruments | 61 ₽ | ||
LME49721MA Texas Instruments | 108 ₽ | ||
LME49721MA/NOPB Texas Instruments | 131 ₽ |
Описание: ИС, OP усилитель, 5 В, RRIO, SMD
LME49721 High Performance, High Fidelity Rail-to-Rail Input/Output Audio Operational Amplifier
October 2007
General Description
The LME49721 is a low distortion, low noise Rail-to-Rail Input/ Output operational amplifier optimized and fully specified for high performance, high fidelity applications.
Combining advanced leading-edge process technology with state-of-the-art circuit design, the LME49721 Rail-to-Rail Input/Output operational amplifier delivers superior signal amplification for outstanding performance. The LME49721 combines a very high slew rate with low THD+N to easily satisfy demanding applications. To ensure that the most challenging loads are driven without compromise, the LME49721 has a high slew rate of ±8.5V/s and an output current capability of ±9.7mA. Further, dynamic range is maximized by an output stage that drives 10k loads to within 10mV of either power supply voltag
- Количество каналов: 2
- Диапазон напряжения питания: 2.2 В ... 5.5 В
- THD + N: 0.0002% @ 600 Ом, VDD=5V
- Load Impedance: 600 Ом
- Amplifier Case Style: SOIC
- Количество выводов: 8
- SVHC: No SVHC (15-Dec-2010)
- Тип корпуса: SOIC
- Input Offset Voltage Max: 1.5 мВ
- Load Impedance Min: 600 Ом
- Number of Amplifiers: 2
- Рабочий диапазон температрур: -40°C ... +85°C
- Slew Rate: 8.5 В/мкс
- Способ монтажа: SMD
- Gain Bandwidth: 20 МГц
- I/O Type: Rail-Rail I/O
- Op Amp Type: Low Noise
Дополнительные аксессуары:
- Electrolube - HTS35SL
