Datasheet LM4952TS - National Semiconductor Даташит усилитель, аудио, стерео 3.1 Вт, SMD, 4952 — Даташит
Наименование модели: LM4952TS
![]() 35 предложений от 19 поставщиков Микросхема Усилитель звуковой частоты, Audio Amp Speaker 2CH Stereo 3.8W Class-AB 10Pin(9+Tab) TO-263 Rail | |||
LM4952TS/NOPB Texas Instruments | 166 ₽ | ||
LM4952TS/NOPB Texas Instruments | 175 ₽ | ||
LM4952TS Texas Instruments | по запросу | ||
Описание: Усилитель, аудио, стерео 3.1 Вт, SMD, 4952
LM4952 3.1W Stereo-SE Stereo Audio Power Amplifier with DC Volume Control
August 2004
LM4952 3.1W Stereo-SE Audio Power Amplifier with DC Volume Control
General Description
The LM4952 is a dual audio power amplifier primarily designed for demanding applications in flat panel monitors and TV's.
It is capable of delivering 3.1 watts per channel to a 4 single-ended load with less than 1% THD+N when powered by a 12VDC power supply. Eliminating external feedback resistors, an internal, DCcontrolled, volume control allows easy and variable gain adjustment. Boomer audio power amplifiers were designed specifically to provide high quality output power with a minimal amount of external components. The LM4952 does not require bootstrap capacitors or snubber circuits. Therefore, it is ideally suited for display applications requiring high power and minimal size. The LM4952 features a low-power consumption active-low shutdown mode. Additionally, the LM4952 features an internal thermal shutdown pr
- Количество каналов: 2
- Диапазон напряжения питания: 9.6 В ... 16 В
- THD + N: 0.08% @ 800 мВт, VDD=12V
- Load Impedance: 4 Ом
- Amplifier Case Style: TO-263
- Количество выводов: 9
- SVHC: No SVHC (15-Dec-2010)
- Тип корпуса: TO-263 (D2-Pak)
- Amplifier Type: Power
- Семейство: 4952
- IC Generic Number: 4952
- Load Impedance Min: 4 Ом
- Количество логических функций: 4952
- Number of Amplifiers: 2
- Рабочий диапазон температрур: -40°C ... +85°C
- Output Power Pout: 3.1 Вт @ 4 Ом
- Power Rating RMS: 3.1 Вт
- Supply Voltage + Nom: 12 В
- Способ монтажа: SMD
Дополнительные аксессуары:
- Fischer Elektronik - WLPG 02
