Datasheet LM4875M - National Semiconductor Даташит усилитель, аудио, 1 Вт BOOMER, 4875, SO-8-8 — Даташит
Наименование модели: LM4875M
![]() 47 предложений от 21 поставщиков Усилитель мощности звука с регулятором громкости постоянного тока и переключателем для наушников | |||
LM4875M/NOPB Texas Instruments | 27 ₽ | ||
LM4875M/NOPB Texas Instruments | от 34 ₽ | ||
LM4875M Texas Instruments | 78 ₽ | ||
LM4875M/NOPB Texas Instruments | 89 ₽ |
Описание: Усилитель, аудио, 1 Вт BOOMER, 4875, SO-8-8
LM4875 750 mW Audio Power Amplifier with DC Volume Control and Headphone Switch
January 2002
General Description
The LM4875 is a mono bridged audio power amplifier with DC voltage volume control.
The LM4875 is capable of delivering 750mW of continuous average power into an 8 load with less than 1% THD when powered by a 5V power supply. Switching between bridged speaker mode and headphone (single ended) mode is accomplished using the headphone sense pin. To conserve power in portable applications, the LM4875's micropower shutdown mode (IQ = 0.7µA, typ) is activated when less than 300mV is applied to the DC Vol/SD pin. Boomer audio power amplifiers are designed specifically to provide high power audio output while maintaining high fidelity. They require few external components and operate on low supply voltages.
- Количество каналов: 1
- Output Power: 1 Вт
- Диапазон напряжения питания: 2.7 В ... 5.5 В
- THD + N: 0.6% @ 300 мВт, 8 Ом, VDD=5V
- Load Impedance: 8 Ом
- Amplifier Case Style: SOIC
- Количество выводов: 8
- SVHC: No SVHC (15-Dec-2010)
- Тип корпуса: SO
- Amplifier Type: Power
- Bandwidth: 20 кГц
- Семейство: 4875
- IC Generic Number: 4875
- Input Offset Voltage Max: 50mV
- Load Impedance Min: 8 Ом
- Количество логических функций: 4875
- Number of Amplifiers: 1
- Рабочий диапазон температрур: -40°C ... +85°C
- Output Power Pout: 750 мВт @ 8 Ом
- Power Rating RMS: 750 мВт
- Supply Voltage + Nom: 5.5 В
- Способ монтажа: SMD
