Datasheet LM3886T/NOPB - National Semiconductor Даташит ИС, усилитель, аудио POWER, MONO — Даташит
Наименование модели: LM3886T/NOPB
![]() 30 предложений от 22 поставщиков IC: аудиоусилитель; Pвых: 68Вт; 20÷84ВDC; Ch: 1; Класс усил: AB; 4Ом | |||
LM3886T/NOPB Texas Instruments | 324 ₽ | ||
LM3886T/NOPB Texas Instruments | по запросу | ||
LM3886T/NOPB20/TUBE(L Texas Instruments | по запросу | ||
LM3886TNOPB Texas Instruments | по запросу |
Описание: ИС, усилитель, аудио POWER, MONO
LM3886 Overture Audio Power Amplifier Series High-Performance 68W Audio Power Amplifier w/Mute
October 2003
LM3886 OvertureTM Audio Power Amplifier Series High-Performance 68W Audio Power Amplifier w/Mute
General Description
The LM3886 is a high-performance audio power amplifier capable of delivering 68W of continuous average power to a 4 load and 38W into 8 with 0.1% THD+N from 20Hz20kHz.
The performance of the LM3886, utilizing its Self Peak Instantaneous Temperature (°Ke) (SPiKeTM) protection circuitry, puts it in a class above discrete and hybrid amplifiers by providing an inherently, dynamically protected Safe Operating Area (SOA). SPiKe protection means that these parts are completely safeguarded at the output against overvoltage, undervoltage, overloads, including shorts to the supplies, thermal runaway, and instantaneous temperature peaks. The LM3886 maintains an excellent signal-to-noise ratio of greater than 92dB with a typical low noise floor of 2.0µV. It exhibits extreme
- Amplifier Class: AB
- Количество каналов: 1
- Output Power: 68 Вт
- Диапазон напряжения питания: 20 В ... 84 В
- THD + N: 0.03% @ 30 Вт, 8 Ом, V=28V
- Load Impedance: 4 Ом
- Amplifier Case Style: TO-220
- Количество выводов: 11
- SVHC: No SVHC (15-Dec-2010)
- Тип корпуса: TO-220
- Bandwidth: 3 МГц
- Input Offset Voltage Max: 10mV
- Load Impedance Min: 4 Ом
- Number of Amplifiers: 1
- Рабочий диапазон температрур: -20°C ... +85°C
- Output Power Pout: 68 Вт
- Power Rating RMS: 68 Вт
- Slew Rate: 19 В/мкс
- Способ монтажа: Through Hole
