Datasheet LM1875T/NOPB - National Semiconductor Даташит ИС, OP усилитель, SINGLE, 70 кГц — Даташит
National Semiconductor LM1875T/NOPB
Наименование модели: LM1875T/NOPB
53 предложений от 26 поставщиков
Усилители.Описание: Audio Amplifiers 20-W AUDIO POWER AMPТип: Одноканальный усилитель НЧ серии LM1875Потребляемый ток: 70 мАКоличество: каналов - 1Вес брутто: 3.73Транспортная упаковка:...
LM1875T/NOPB
от 56 ₽
LM1875T/NOPB
99 ₽
МосЧип
LM1875T@NOPB
LM1875T/NOPB
Rohm
Описание: ИС, OP усилитель, SINGLE, 70 кГц
data sheetСкачать Data Sheet
LM1875 20W Audio Power Amplifier
July 2002
General Description
The LM1875 is a monolithic power amplifier offering very low distortion and high quality performance for consumer audio applications.
The LM1875 delivers 20 watts into a 4 or 8 load on ± 25V supplies. Using an 8 load and ± 30V supplies, over 30 watts of power may be delivered. The amplifier is designed to operate with a minimum of external components. Device overload protection consists of both internal current limit and thermal shutdown. The LM1875 design takes advantage of advanced circuit techniques and processing to achieve extremely low distortion levels even at high output power levels. Other outstanding features include high gain, fast slew rate and a wide power bandwidth, large output voltage swing, high current capability, and a very wide supply range. The amplifier is internally compensated and stable for gains of 10 or greater.
  • Amplifier Class: B
  • Количество каналов: 1
  • Output Power: 25 Вт
  • Диапазон напряжения питания: 16 В ... 60 В
  • THD + N: 0.015% @ 20 Вт, 8 Ом, VCC=25V
  • Load Impedance: 8 Ом
  • Amplifier Case Style: TO-220
  • Количество выводов: 5
  • SVHC: No SVHC (15-Dec-2010)
  • Тип корпуса: TO-220
  • Bandwidth: 70 кГц
  • Input Offset Voltage Max: 15mV
  • Load Impedance Min: 4 Ом
  • Number of Amplifiers: 1
  • Рабочий диапазон температрур: 0°C ... +70°C
  • Output Power Pout: 25 Вт
  • Power Rating RMS: 20 Вт
  • Slew Rate: 8 В/мкс
  • Gain Bandwidth: 5.5 МГц
  • Op Amp Type: Low Distortion
На английском языке: Datasheet LM1875T/NOPB - National Semiconductor IC, OP AMP, SINGLE, 70 kHz
