Источники питания Keen Side
Datasheet 8596060000 - Weidmuller Даташит DIN Mount Relay — Даташит
Weidmuller 8596060000
Наименование модели: 8596060000
Electromechanical Relay 24VDC 3.64KΩ 6A SPDT (( 94mm 6.1mm 93mm)) DIN Rail Coupling Relay
Weidmuller
2 101 ₽
T-electron
8596060000
229 302 ₽
HXD Co.
Weidmuller
ТаймЧипс
Weidmuller
Производитель: Weidmuller
Описание: DIN Mount Relay
data sheetСкачать Data Sheet
Product catalogue | Electronics | Relays | MICROSERIES | 1 changeover contact with hard gold-plated contacts
General ordering data Order No.
Part designation Version EAN Input Rated control voltage Pull-in (sparkover) / drop-out voltage DC coil Rated current DC Pull-in / drop-out current, DC coil Power rating Status indicator Output Continuous current Inrush current Max. switching current Max. switching frequency at rated load Max. switching power Max. switching voltage AC Min. switching power Sparkover time / Drop-out time Switch-off delay Switch-on delay Contact data Number of contacts Contact base material Mechanical service life Rated data Climate Connection system
8596060000 MRS 24Vdc 1CO 5uAu Relays, 1 CO contact, 24 V DC ±20% , 6 A, Screw connection 4032248254958 24 V DC ±20% 15.4V/6.5V 6.6 mA 4mA/1.2mA 160 mW Green LED 6A 6A 6A 0.1 Hz 1500 VA 250 V 1 V / 1 mA 6.6 ms / 5.8 ms 5.8ms 6.6ms 1 AgSnO 5m Au 6 20*10 switching cycles 40°C/93% rel. humidity, no condensation Screw conne
  • Тип реле: General Purpose
  • Coil Voltage VDC Nom: 24 В
  • Contact Current Max: 6 А
  • Contact Voltage AC Nom: 250 В
  • Contacts: 1CO
  • Coil Type: DC
  • Coil Current: 6.6 мА
  • Nom Operating Power: 160 мВт
  • Способ монтажа: DIN Rail
На английском языке: Datasheet 8596060000 - Weidmuller DIN Mount Relay
