Datasheet 7901620000 - Weidmuller Даташит DIN Mount реле — Даташит
Weidmuller 7901620000
Наименование модели: 7901620000
17 предложений от 11 поставщиков
Реле Мощности, WEIDMULLER 7901620000 Power Relay, SPDT, 24VDC, 6A, MC5R Series, DIN Rail
Оптулс
7901620000 WEIDMUELLER DK 5R RELAY, 24VDC, 1 C/O CONTACT 0
Weidmuller
1 836 ₽
Weidmuller
3 228 ₽
Зенер
Россия и страны ТС
7901620000
Weidmuller
от 8 344 ₽
T-electron
7901620000
391 284 ₽
Производитель: Weidmuller
Описание: DIN Mount реле
data sheetСкачать Data Sheet
Datasheet
picoPakTM Relay Modules
picoPak TM relay modules are compact - just 6mm or 8mm wide - and ideal for control applications where rail space is limited.
There are several versions to choose from and all mount on both 32mm and 35mm DIN rails. Versions include: MC5R 1A: Dual input voltages and a 1 form A (SPSTNO), 4A contact, 6mm wide. CSA Class 1 Div 2 approved. MC5R 1C: 24Vdc input and a 1 form C (SPDT), 6A contact, 6mm wide. MC6R 1C: Dual 24V and 120V input, 1 form C, 0.5A contact. Gold flashed contact, perfect for interfacing to PLC inputs. MC6RF: 24V or 120V input and 1 form A, 5A contact. User serviceable fuse on output. 120V input version includes leakage immunity up to 1,5mA - perfect for use with PLC triac outputs. Other features: -combifoot for mounting on 32mm and 35mm DIN rails -input status LEDs -CSA approved -optional jumper comb for cross connections
United States Weidmuller Inc. 821 Southlake Blvd. Richmond, Virginia 23236 Telephone: (800) 849-9343 Facsimile: (8
  • Coil Current: 7 мА
  • Coil Type: DC
  • Coil Voltage VDC Nom: 24 В
  • Contact Current Max: 6 А
  • Contact Voltage AC Nom: 250 В
  • Contact Voltage DC Nom: 30 В
  • Конфигурация контактов: SPDT
  • Тип реле: General Purpose
На английском языке: Datasheet 7901620000 - Weidmuller DIN Mount Relay
