Datasheet SSU-RIC-1 - Space Age Electronics Даташит Control Relay — Даташит
Space Age Electronics SSU-RIC-1
Наименование модели: SSU-RIC-1
Производитель: Space Age Electronics
Описание: Control Relay
data sheetСкачать Data Sheet
Coil Energized LED
RIC
RIC Series Relays (1 - 4)
The RIC Series is ideal for applications where remote relays are required for control or status feedback.
They are suitable for use with HVAC, temperature control, fire alarms, security, energy management and lighting control systems.
The SSU-RIC-1 Relay, SPDT, provides 10.0 Amp resistive form C contacts. The relay coil may be energized by one of three input voltages: 24VDC, 24VAC, or 115VAC. SAE PN# SSU-RIC-1 Coil Energized LED
  • Coil Voltage VAC Nom: 115 В
  • Coil Voltage VDC Nom: 24 В
  • Contact Current Max: 10 А
  • Contact Voltage AC Nom: 115 В
  • Contact Voltage DC Nom: 28 В
  • Contacts: SPDT
  • Coil Type: AC / DC
  • Coil Current: 26 мА
  • Relay Mounting: Panel
SSURIC1, SSU RIC 1
На английском языке: Datasheet SSU-RIC-1 - Space Age Electronics Control Relay
