Datasheet HY2A112DC - IMO Precision Controls Даташит Реле, DPNO, 12 В DC — Даташит
Наименование модели: HY2A112DC
Реле Мощности, RELAY, DPNO, 12VDC; Series: HY; Relay Type: General Purpose; Voltage, Coil DC Nom: 12V; Resistance, Coil: 75Ω; Pole... | |||
HY2A112DC IMO Precision Controls | 858 ₽ |
Производитель: IMO Precision Controls
Описание: Реле, DPNO, 12 В DC
High Capacity Relay HY
3mm contact gap as standard 30A high capacity relay able to withstand momentary voltage drops to 50% rated Class F insulation Heavy load up to 7500VA UL/cUL approved
Options and ordering codes
HY
Power Relay
- Тип реле: General Purpose
- Coil Voltage VDC Nom: 12 В
- Contact Current Max: 25 А
- Contact Voltage AC Nom: 250 В
- Coil Resistance: 75 Ом
- Contact Configuration: DPNO
- Coil Type: DC Coil
- Coil Current: 160 мА
- Nom Operating Power: 1.9 Вт
- Relay Mounting: Plug-In
- Внешняя длина / высота: 36 мм
- Внешняя ширина: 51.5 мм
- External Depth: 34.9 мм
- SVHC: No SVHC (15-Dec-2010)
- Contact Current AC Max: 30 А
- Contact Voltage AC Max: 250 В
- Mounting Type: PCB
- Number of Poles: 2
- Семейство: HY
- Approval Bodies: CUR, TUV
- Approval Category: VDE 0435
- Switch Current Max: 25 А
- Switching Power Max: 5500 VA
