Datasheet RH2B-UDC-24V - IDEC Даташит Power Relay — Даташит
IDEC RH2B-UDC-24V
Наименование модели: RH2B-UDC-24V
22 предложений от 11 поставщиков
AVX Advanced Ceramic Capacitors for Power Supply, High Voltage and Tip and Ring Applications
RH2B-UDC24V
IDEC
557 ₽
RH2B-UDC24V
IDEC
592 ₽
HXD Co.
RH2B-UDC24V
IDEC
1 324 ₽
RH2B-UDC24V
Производитель: IDEC
Описание: Power Relay
data sheetСкачать Data Sheet
RH Series RH Series -- General Purpose Midget Relays
Key features of the RH series include: · Compact midget size saves space · High switching capacity (10A) · Choice of blade or PCB style terminals · Relay options include indicator light, check button, and top mounting bracket · DIN rail, surface, panel, and PCB type sockets available for a wide range of mounting applications Contact Material Contact Resistance Minimum Applicable Load Operating Time
Silver cadmium oxide 50m maximum (initial value) 24V DC/30mA, 5V DC/100mA (reference value) SPDT (RH1), DPDT (RH2): 20ms maximum 3PDT (RH3), 4PDT (RH4): 25ms maximum SPDT (RH1), DPDT (RH2): 20ms maximum 3PDT (RH3), 4PDT (RH4): 25ms maximum 110% of the rated voltage
Relays
E
  • Семейство: RH
  • Тип реле: General Purpose
  • Coil Voltage VDC Nom: 24 В
  • Contact Current Max: 10 А
  • Contact Voltage AC Nom: 220 В
  • Contact Voltage DC Nom: 30 В
  • Coil Resistance: 67 Ом
  • Contact Configuration: DPDT
  • Coil Type: DC Coil
  • Coil Current: 36.9 мА
  • Nom Operating Power: 900 мВт
  • Relay Mounting: Plug-In
  • Внешняя длина / высота: 60 мм
  • Внешняя ширина: 21.5 мм
  • External Depth: 27.5 мм
  • SVHC: No SVHC (18-Jun-2010)
  • Contact Current AC Max: 7.5 А
  • Contact Current DC Max: 10 А
  • Contact Voltage AC Max: 220 В
  • Contact Voltage DC Max: 30 В
  • Mounting Type: Plug-In
  • Number of Poles: 2
RH2BUDC24V, RH2B UDC 24V
На английском языке: Datasheet RH2B-UDC-24V - IDEC Power Relay
