Datasheet DM87N-2011-35-1024 - Durakool Даташит POWER Реле SPDT-CO 24 В DC, 10 А, PC BOARD — Даташит
Durakool DM87N-2011-35-1024
Наименование модели: DM87N-2011-35-1024
6 предложений от 4 поставщиков
Реле и Аксессуары , Power Relay; Series: DM87; Relay Type: High Sensitivity; Coil Voltage VDC Nom: 12V; Coil Resistance: 360Ω; No....
DM87N-2011-35-1012
Durakool
299 ₽
DM87N-2011-35-1012
Durakool
368 ₽
DM87N-2011-35-5012
Durakool
от 371 ₽
Элитан
DM87N-2011-35-5120
1 521 ₽
Производитель: Durakool
Описание: POWER Реле SPDT-CO 24 В DC, 10 А, PC BOARD
data sheetСкачать Data Sheet
DM87
industrial relays
DM87N sensitive
Contacts Contact number & arrangement Contact material Max.
switching voltage Min. switching voltage Rated load Min. switching current Max. inrush current Rated current Max. breaking capacity Min. breaking capacity Resistance Max. operating frequency · at rated load · no load Coil Rated voltage Must release voltage Operating range of supply voltage Rated power consumption Insulation Insulation category Insulation rated voltage Rated surge voltage Overvoltage category Insulation pollution degree Dielectric strength · coil - contact · contact - contact Contact - coil distance · clearance · creepage General data Operating time (typical value) Release time (typical value) Electrical life · resistive AC1 · cos · L/R=40 ms Mechanical life (cycles) Dimensions (L x W x H) Weight Ambient temperature Cover protection category Environmental protection Shock resistance Vibration resistance Solder bath temperature Soldering time
· Cadmium - free contacts · H
  • Тип реле: High Sensitivity
  • Coil Voltage VDC Nom: 24 В
  • Contact Current Max: 10 А
  • Contact Voltage AC Nom: 250 В
  • Contact Voltage DC Nom: 24 В
  • Coil Resistance: 1440 Ом
  • Contacts: SPDT-C/O
DM87N2011351024, DM87N 2011 35 1024
На английском языке: Datasheet DM87N-2011-35-1024 - Durakool POWER RELAY SPDT-CO 24 V DC, 10 A, PC BOARD
