Datasheet LPC2212FBD144,551 - NXP Даташит ИС, 16/32 бит микроконтроллер ARM7, SMD, LPC2212 — Даташит
Наименование модели: LPC2212FBD144,551
9 предложений от 9 поставщиков Микроконтроллеры ARM ARM7 128KF/16KR/ADC | |||
LPC2212FBD144,551 | 80 ₽ | ||
LPC2212FBD144,551 NXP | по запросу | ||
Производитель: NXP
Описание: ИС, 16/32 бит микроконтроллер ARM7, SMD, LPC2212
LPC2212/2214
16/32-bit ARM microcontrollers; 128/256 kB ISP/IAP flash with 10-bit ADC and external memory interface
Rev.
04 -- 3 January 2008 Product data sheet
1. General description
The LPC2212/2214 are based on a 16/32-bit ARM7TDMI-S CPU with real-time emulation and embedded trace support, together with 128/256 kB of embedded high-speed flash memory. A 128-bit wide memory interface and a unique accelerator architecture enable 32-bit code execution at maximum clock rate. For critical code size applications, the alternative 16-bit Thumb mode reduces code by more than 30 % with minimal performance penalty. With their 144-pin package, low power consumption, various 32-bit timers, 8-channel 10-bit ADC, PWM channels and up to nine external interrupt pins these microcontrollers are particularly suitable for industrial control, medical systems, access control and point-of-sale. Number of available fast GPIOs ranges from up to 76 pins (with external memory) through up to 112 pins (single-ch
- Семейство: LPC2
- Размер ОЗУ: 16 Кб
- Количество таймеров: 4
- Количество каналов ШИМ: 6
- Тип корпуса: LQFP
- Рабочий диапазон температрур: -40°C ... +85°C
- Количество выводов: 144
- Тактовая частота: 60 МГц
- Размер памяти Flash: 128 Кб
- IC Generic Number: LPC2212
- Интерфейс: I2C, SPI, UART
- Размер памяти: 128K
- Тип памяти: FLASH
- Особые функции: 16 Кб on-chip Static RAM, Two 32- бит timers (with four capture and four compare channels), ШИМ unit (six outputs), Real Time Clock and Watchdog, On-chip crystal oscillator, Two low power modes, Idle and Power-down, 128 Кб on-chip Flash Program Memory
- Количество входов АЦП: 8
- Количество битов: 16 / 32
- Количество внешних прерываний: 3
- Количество линий ввода/вывода: 112
- Разрядность таймера: 32
- Количество COM портов: 2xUART, I2C, 2xSPI
- Способ монтажа: SMD
- Диапазон напряжения питания: 3 В ... 3.6 В
Дополнительные аксессуары:
- IQD FREQUENCY PRODUCTS - LF A158K
- IQD FREQUENCY PRODUCTS - LF A161K
- Roth Elektronik - RE471
LPC2212FBD144551, LPC2212FBD144 551
