Datasheet LPC2131FBD64,151 - NXP Даташит ИС, 16/32 бит микроконтроллер ARM7, SMD, LPC2131 — Даташит
Наименование модели: LPC2131FBD64,151
7 предложений от 7 поставщиков Микроконтроллеры ARM ARM7 256KF/8KR/ADC | |||
LPC2131FBD64,151 | 80 ₽ | ||
LPC2131FBD64,151 NXP | по запросу | ||
LPC2131FBD64,151 | по запросу | ||
LPC2131FBD64.151 NXP | по запросу |
Производитель: NXP
Описание: ИС, 16/32 бит микроконтроллер ARM7, SMD, LPC2131
LPC2131/32/34/36/38
Single-chip 16/32-bit microcontrollers; 32/64/128/256/512 kB ISP/IAP flash with 10-bit ADC and DAC
Rev.
04 -- 16 October 2007 Product data sheet
1. General description
The LPC2131/32/34/36/38 microcontrollers are based on a 16/32-bit ARM7TDMI-S CPU with real-time emulation and embedded trace support, that combine the microcontroller with 32 kB, 64 kB, 128 kB, 256 kB and 512 kB of embedded high-speed flash memory. A 128-bit wide memory interface and a unique accelerator architecture enable 32-bit code execution at maximum clock rate. For critical code size applications, the alternative 16-bit Thumb mode reduces code by more than 30 % with minimal performance penalty. Due to their tiny size and low power consumption, these microcontrollers are ideal for applications where miniaturization is a key requirement, such as access control and point-of-sale. With a wide range of serial communications interfaces and on-chip SRAM options of 8 kB, 16 kB, and 32 kB, they are ver
- Семейство: LPC2
- Размер ОЗУ: 8 Кб
- Количество таймеров: 4
- Количество каналов ШИМ: 6
- Тип корпуса: LQFP
- Рабочий диапазон температрур: -40°C ... +85°C
- Количество выводов: 64
- Тактовая частота: 60 МГц
- Размер памяти Flash: 32 Кб
- IC Generic Number: LPC2131
- Интерфейс: I2C, SPI, UART
- Размер памяти: 32K
- Тип памяти: FLASH
- Особые функции: 8 Кб on-chip Static RAM, Two 32- бит timers (with four capture and four compare channels), ШИМ unit (six outputs), Real Time Clock and Watchdog, On-chip crystal oscillator, Two low power modes, Idle and Power-down, 32 Кб on-chip Flash Program Memory, 128- бит wide interface/accelerator
- Количество входов АЦП: 8
- Количество битов: 16 / 32
- Количество внешних прерываний: 4
- Количество линий ввода/вывода: 47
- Разрядность таймера: 32
- Количество COM портов: 2xUART, 2xI2C, 2xSPI
- Способ монтажа: SMD
- Диапазон напряжения питания: 3 В ... 3.6 В
Дополнительные аксессуары:
- IQD FREQUENCY PRODUCTS - LF A158K
- Roth Elektronik - RE471
LPC2131FBD64151, LPC2131FBD64 151
