Источники питания Keen Side
Datasheet AF16-30-10-12 - ABB Даташит CONTACTOR, 3P, 130 В, 7.5KW — Даташит
ABB AF16-30-10-12
Наименование модели: AF16-30-10-12
AF16 3Pole Contactor; 10.5A; 7.5kW; 130V dc Coil
AF16-30-10-12
ABB
6 531 ₽
AF16-30-10-12
ABB
6 949 ₽
Элитан
AF16-30-10-12
ABB
33 177 ₽
Производитель: ABB
Описание: CONTACTOR, 3P, 130 В, 7.5KW
data sheetСкачать Data Sheet
AF09 ...
AF38 3-pole Contactors up to 18.5 kW / 20 hp
Overview ..................................................................................................................................... 2 Ordering Details ­ AF09 ... AF38 3-pole Contactors ............................................................................................... 4 ­ AF..Z Additional Coils .................................................................................................................. 5 Technical Data ............................................................................................................................ 6 Main Accessory Fitting Details ................................................................................................. 11 Accessory Ordering Details and Technical Data...................................................................... 12 Terminal Marking and Positioning ....................................................................................
  • Тип реле: Contactor
  • Coil Voltage VAC Nom: 130 В
  • Coil Voltage VDC Nom: 130 В
  • Coil Type: AC/DC
  • Nom Operating Power: 7.5kW
  • Внешняя длина / высота: 80 мм
  • Внешняя ширина: 46 мм
  • External Depth: 77 мм
  • Contact Current AC Max: 18 А
  • No. of Poles: 3
  • Operating Temperature Max: 70°C
  • Series: Electronic overload relays
  • Temperature Operating Min: -40°C
  • Termination Type: Screw
  • Type: 10 hp
AF16301012, AF16 30 10 12
На английском языке: Datasheet AF16-30-10-12 - ABB CONTACTOR, 3P, 130 V, 7.5KW
