Datasheet 3RH11401BB40 - Siemens Даташит Реле, CONTROL, 4NO, 24 В DC — Даташит
Наименование модели: 3RH11401BB40
Купить 3RH11401BB40 на РадиоЛоцман.Цены — от 4 285 до 4 420 ₽ 6 предложений от 6 поставщиков Control contactor; External Depth: 106mm; External Width: 45mm; Length/Height, External: 57.5mm; Operating Temp. Max:... | |||
3RH1140-1BB40 | 4 285 ₽ | ||
3RH11401BB40 | 4 319 ₽ | ||
3RH1140-1BB40 | 4 420 ₽ | ||
3RH1140-1BB40 | по запросу |
Производитель: Siemens
Описание: Реле, CONTROL, 4NO, 24 В DC
3RT, 3RH, 3TB, 3TC, 3TH, 3TK Contactors for Special Applications
Contactors with Extended Tolerance 0.7 ...
1.25 x Us , for Railway Applications
3RT10 motor contactors, 5.5 ... 45 kW
DC operation · DC solenoid system Screw terminals For screw and snap-on mounting onto standard mounting rail Contactor control unit Solenoid fitted with varistor
Rated data AC-2 and AC-3 Tu: up to 70 °C Rated operational current Ie at 400 V A Auxiliary contacts1) Rated control DT supply voltage Us Screw terminals PU PS* (UNIT, SET, M) Price per PU PG Weight per PU approx.
- Тип реле: Contactor
- Coil Voltage VDC Nom: 24 В
- Contact Configuration: 4PNO
- Coil Type: DC
- Relay Mounting: DIN Rail
- Внешняя длина / высота: 57.5 мм
- Внешняя ширина: 45 мм
- External Depth: 106 мм
- Contact Current AC Max: 6 А
- Contact Voltage AC Max: 230 В
- Mounting Type: DIN Rail
- No. of Poles: 4
- Operating Temperature Max: 60°C
- Series: 3RH11
- Temperature Operating Min: -25°C
- Approval Bodies: UL, CSA
- Dielectric Strength VAC: 600 В AC
- IP / NEMA Rating: 20
- Main Contact Current AC3 Max: 10 А
- Switch Current Max: 10 А
