Datasheet 60.42.9.024.0000 - Finder Даташит Реле, PCB, DPCO, 24 В DC — Даташит
Наименование модели: 60.42.9.024.0000
Купить 60.42.9.024.0000 на РадиоЛоцман.Цены — от 1 486 до 1 685 ₽ RELAY, PCB, DPCO, 24VDC; Series: 60; Relay Type: General Purpose; Voltage, Coil DC Nom: 24V; Coil Resistance: 445Ω;... | |||
60.42.9.024.0000 Finder | 1 486 ₽ | ||
60.42.9.024.0000 Finder | 1 487 ₽ | ||
60.42.9.024.0000 Finder | 1 685 ₽ |
Производитель: Finder
Описание: Реле, PCB, DPCO, 24 В DC
60 Series - General purpose relays 6 - 10 A Features
Plug-in mount 10 A General purpose relay & 3 pole changeover contacts Cadmium Free contacts (preferred version) · AC coils & DC coils · UL Listed (certain relay/socket combinations) · Contact material options · Lockable test button with mechanical flag indicator (preferred version) · 90 series sockets, coil EMC suppression and timer accessories
· ·2
60.12
60.13
- Тип реле: General Purpose
- Coil Voltage VDC Nom: 24 В
- Contact Current Max: 20 А
- Contact Voltage AC Nom: 250 В
- Coil Resistance: 445 Ом
- Contact Configuration: DPCO
- Coil Type: DC Coil
- Coil Current: 53.9 мА
- Nom Operating Power: 1.3 Вт
- Relay Mounting: PC Board
- Внешняя длина / высота: 36 мм
- Внешняя ширина: 32.2 мм
- External Depth: 43 мм
- Contact Current AC Max: 10 А
- Contact Current DC Max: 10 А
- Contact Voltage AC Max: 250 В
- Contact Voltage DC Max: 30 В
- Mounting Type: PCB
- No.
of Poles: 2
- Operating Temperature Max: 70°C
- Series: 60
- Temperature Operating Min: -40°C
- AC Coil Power: 2.2VA
- Approval Bodies: BSI, VDE, CSA, SEV, IMQ, UL, DEMKO, RINA, BEAB
- Coil Operating Lower Percent Limit: 80%
- Coil Operating Upper Percent Limit: 110%
- Contact Material: Silver Nickel
- DC Coil Power: 1.3 Вт
- Dielectric Strength VDC: 2000 В
- Operating Time: 20 мс
- PCB Hole Diameter: 1.5 мм
- Release Time: 20ms
- Switch Current Max
- Switched Current Max: 20 А
- Switching Power Max: 2500VA
