Datasheet A110-30-11-24V-50HZ - ABB Даташит CONTACTOR, 55KW, 110 А — Даташит
ABB A110-30-11-24V-50HZ
Наименование модели: A110-30-11-24V-50HZ
ABB A110-30-11-81 Contactor, 24VAC Coil, 110A at 3-Phase, 140A at 1-Phase
A110-30-11-81
ABB
27 098 ₽
A110-30-11-51
ABB
30 292 ₽
LifeElectronics
A110-30-11-81
ТаймЧипс
A110-30-11-80
Производитель: ABB
Описание: CONTACTOR, 55KW, 110 А
data sheetСкачать Data Sheet
Control Gear
Contents
3 Pole Contactors..........................................................................
4 Pole Contactors.......................................................................... Mini Contactors.............................................................................. Manual Motor Starters .................................................................. Field Bus Plugs.............................................................................. Softstarters.................................................................................... Pilot Devices.................................................................................. Switching Power Supplies (CP Range) ..........................................
2-2 2-20 2-37 2-42 2-49 2-54 2-58 2-72
Return to main index
  • Тип реле: Contactor
  • Coil Voltage VAC Nom: 24 В
  • Contact Configuration: DPCO
  • Внешняя длина / высота: 148 мм
  • Внешняя ширина: 102 мм
  • External Depth: 123.5 мм
  • SVHC: No SVHC (18-Jun-2010)
  • Contact Current AC Max: 110 А
  • Contact Voltage AC Max: 400 В
  • Mounting Type: Panel
  • No. of Poles: 3
  • Approval Bodies: UL, CSA
  • Coil Operating Voltage: 24 В
  • Contact Current Max: 110 А
  • Frame Size: A110
  • IP / NEMA Rating: 20
  • Main Contact Current AC1 Max: 160 А
  • Main Contact Current AC3 Max: 110 А
  • Power Rating: 55kW
A110301124V50HZ, A110 30 11 24V 50HZ
На английском языке: Datasheet A110-30-11-24V-50HZ - ABB CONTACTOR, 55KW, 110 A
