Datasheet A50-30-11-230V-50HZ - ABB Даташит CONTACTOR, 22KW, 50 А — Даташит
Наименование модели: A50-30-11-230V-50HZ
Купить A50-30-11-230V-50HZ на РадиоЛоцман.Цены — от 16 952 до 18 484 ₽ CONTACTOR, 22kW, 50A; Relay Type: Contactor; Nom Coil Voltage AC: 230V; Contact Configuration: DPCO; External Length ... | |||
A50-30-11-230V-50HZ ABB | 16 952 ₽ | ||
A50-30-11-230V-50HZ ABB | 18 484 ₽ |
Производитель: ABB
Описание: CONTACTOR, 22KW, 50 А
Control Gear
Contents
3 Pole Contactors..........................................................................
4 Pole Contactors.......................................................................... Mini Contactors.............................................................................. Manual Motor Starters .................................................................. Field Bus Plugs.............................................................................. Softstarters.................................................................................... Pilot Devices.................................................................................. Switching Power Supplies (CP Range) ..........................................
2-2 2-20 2-37 2-42 2-49 2-54 2-58 2-72
Return to main index
- Тип реле: Contactor
- Coil Voltage VAC Nom: 230 В
- Contact Configuration: DPCO
- Внешняя длина / высота: 110 мм
- Внешняя ширина: 81.7 мм
- External Depth: 108 мм
- SVHC: No SVHC (18-Jun-2010)
- Contact Current AC Max: 50 А
- Contact Voltage AC Max: 400 В
- Mounting Type: Panel
- No. of Poles: 3
- Approval Bodies: UL, CSA
- Coil Operating Voltage: 240 В
- Contact Current Max: 50 А
- Frame Size: A50
- IP / NEMA Rating: 10, 20
- Main Contact Current AC1 Max: 100 А
- Main Contact Current AC3 Max: 50 А
- Power Rating: 22kW
A503011230V50HZ, A50 30 11 230V 50HZ
