Популярные микроконтроллеры Nuvoton серий М2354 и М251 со склада компании Смарт-ЭК
Datasheet DILEM-10(380V50HZ,440V60HZ) - Moeller Даташит CONTACTOR, MINI, 4KW — Даташит
Moeller DILEM-10(380V50HZ,440V60HZ)
Наименование модели: DILEM-10(380V50HZ,440V60HZ)
Контест
DILEM-10-C(380V50HZ,440V60HZ)3 583 ₽
Производитель: Moeller
Описание: CONTACTOR, MINI, 4KW
data sheetСкачать Data Sheet
Type: DILEM-10(380V50HZ,440V60HZ) Article No.: 051787
Ordering information
Actuating voltage Description Connection technique 380 V 400 V Max.
rating for three-phase motors, 50 ­ 60 Hz AC-3 220 V 230 V Max. rating for three-phase motors, 50 ­ 60 Hz AC-3 380 V 400 V Max. rating for three-phase motors, 50 ­ 60 Hz AC-3 660 V 690 V Max. rating for three-phase motors, 50 ­ 60 Hz AC-4 220 V 230 V Max. rating for three-phase motors, 50 ­ 60 Hz AC-4 380 V 400 V Max. rating for three-phase motors, 50 ­ 60 Hz AC-4 660 V 690 V Conventional thermal current I th = I e AC-1 Open Conventional thermal current I th = I e AC-1 Enclosed Contacts M = Make Can be combined with auxiliary contact Ie P P P P P P Ith = Ie Ith = Ie A kW kW kW kW kW kW A A 380V 50Hz, 440V 60Hz 3-pole, with auxiliary contacts Screw terminals 8.8 2.2 4 4 1.5 3 3 20 16 1M ...DILEM ...DILE
Contact sequence
Notes concerning the product group
  • Тип реле: Contactor
  • Внешняя длина / высота: 58 мм
  • Внешняя ширина: 45 мм
  • External Depth: 52 мм
  • Contact Voltage AC Max: 690 В
  • Mounting Type: DIN Rail
  • No. of Poles: 3
  • Series: DILEM
  • Approval Bodies: IEC/EN 60947, VDE0660, CSA, UL
  • Aux Contact Current Max: 10 А
  • Coil Frequency Max: 60Hz
  • Coil Operating Frequency Min: 50Hz
  • Coil Voltage Max: 440 В
  • Coil Voltage Min: 380 В
  • Dielectric Voltage Coil to Contact: 300 В AC
  • Dielectric Voltage Contact to Contact: 300 В AC
  • IP / NEMA Rating: 20
  • Insulation Voltage: 690 В AC
  • Main Contact Current AC1 Max: 20 А
  • Main Contact Current AC3 Max: 9 А
DILEM10(380V50HZ,440V60HZ), DILEM 10(380V50HZ,440V60HZ), DILEM-10(380V50HZ440V60HZ), DILEM-10(380V50HZ 440V60HZ)
На английском языке: Datasheet DILEM-10(380V50HZ,440V60HZ) - Moeller CONTACTOR, MINI, 4KW
