Datasheet SKW25N120 - Infineon Даташит IGBT, FAST — Даташит
Наименование модели: SKW25N120
![]() 50 предложений от 29 поставщиков Биполярные транзисторы с изолированным затвором (IGBT) FAST IGBT NPT TECH 1200V 25A | |||
SKW25N120FKSA1 Infineon | 27 ₽ | ||
SKW25N120FKSA1 Infineon | от 165 ₽ | ||
SKW25N120 | по запросу | ||
SKW25N120INFINEON/07 Infineon | по запросу |
Производитель: Infineon
Описание: IGBT, FAST
SKW25N120
Fast IGBT in NPT-technology with soft, fast recovery anti-parallel EmCon diode
· 40lower Eoff compared to previous generation · Short circuit withstand time 10 µs · Designed for: - Motor controls - Inverter G - SMPS · NPT-Technology offers: - very tight parameter distribution - high ruggedness, temperature stable behaviour - parallel switching capability · Pb-free lead plating; RoHS compliant 1 · Qualified according to JEDEC for target applications · Complete product spectrum and PSpice Models : http://www.infineon.com/igbt/ Type SKW25N120 Maximum Ratings Parameter Collector-emitter voltage DC collector current TC = 25°C TC = 100°C Pulsed collector current, tp limited by Tjmax Turn off safe operating area VCE 1200V, Tj 150°C Diode forward current TC = 25°C TC = 100°C Diode pulsed current, tp limited by Tjmax Gate-emitter voltage Short circuit withstand time Power dissipation TC = 25°C Operating junction and storage temperature Soldering temperature, wavesoldering, 1.6mm (
- Тип транзистора: IGBT
- DC Collector Current: 46 А
- Collector Emitter Voltage Vces: 3.6 В
- Power Dissipation Max: 313 Вт
- Collector Emitter Voltage V(br)ceo: 1200 В
- Корпус транзистора: TO-247AC
- Количество выводов: 3
- Current Ic @ Vce Sat: 25 А
- Current Ic Continuous a Max: 46 А
- Current Temperature: 25°C
- Device Marking: SKW25N120
- Fall Time tf: 39 нс
- Junction Temperature Tj Max: 150°C
- Junction Temperature Tj Min: -55°C
- Package / Case: TO-247AC
- Power Dissipation: 313 Вт
- Power Dissipation Pd: 313 Вт
- Power Dissipation Ptot Max: 313 Вт
- Pulsed Current Icm: 84 А
- Rise Time: 40 нс
- Termination Type: Through Hole
- Полярность транзистора: N
- Voltage Vces: 1200 В
Дополнительные аксессуары:
- Fischer Elektronik - WLK 5
