Datasheet Wago 891-8994/216-802 — Даташит
Соединительный кабель; Штекер - свободный конец; 4-пол.; длиной 8 м; Кодирование А; безгалогенные; Концы проводников, припаянные: 9 мм
891-8994/216-701 Wago | по запросу |
Coding | A |
Цвет | white |
Color of sheathed cable | white |
Conductor preparation | tip-bonded |
Connection type | Plug - free end |
Connector color | white |
Contact material | Copper or copper alloy, surface-treated |
Country of origin | PL |
Cross section of single conductor | 1.5 mm² |
Degree of protection | IP20 |
Durchmesser der Mantelleitung | 8.4 … 10.5 mm |
Fire load | 14.65 MJ |
GTIN | 4055143405515 |
Ground function | with preceding GND contact |
Halogen-free | Yes |
Locking lever | нет |
Locking of plug-in connection | locking lever |
Marking | N ⏚ 2|L 1|L' |
Mating force of a plug-in connection | approx. 20 … 70 N (depending on pole number) |
Mismating protection | Yes |
Number of Poles | 4 |
Pin spacing | 4.4 mm (0.173 inch) |
Potential marking | N ⏚ 2/L 1/L' |
Printing color of mating face | black |
Printing color of sheathed cable | black |
Printing color of strain relief | black |
Rated current | 16 A |
Rated impulse voltage (III / 3) | 6 kV |
Rated voltage (III / 3) | 400 В |
Reaction to fire class per EN 50575 | Eca |
Retention force of a plug-in connection | when locked: > 80N |
Strain relief color | white |
Strip length | 45 мм |
Surrounding air (operating) temperature | -35 … 85 °C |
Total length | 8 m |
Total number of potentials | 4 |
Type of cable | H05Z1Z1-F 4G1.5 |
Type of cable assembly | Connecting cable |
Unmating force of a plug-in connection | when unlocked: approx. 20 … 70 N (depending on pole number) |
Вес | 954.269 г |
Серия: 891 (100 из 1377)
- 891-8994/206-201 891-8994/206-202 891-8994/206-203 891-8994/206-205 891-8994/206-207 891-8994/206-301 891-8994/206-302 891-8994/206-303 891-8994/206-305 891-8994/206-307 891-8994/206-401 891-8994/206-402 891-8994/206-403 891-8994/206-405 891-8994/206-407 891-8994/206-501 891-8994/206-502 891-8994/206-503 891-8994/206-505 891-8994/206-507 891-8994/206-601 891-8994/206-602 891-8994/206-603 891-8994/206-605 891-8994/206-607 891-8994/206-701 891-8994/206-702 891-8994/206-703 891-8994/206-705 891-8994/206-707 891-8994/206-801 891-8994/206-802 891-8994/206-803 891-8994/206-805 891-8994/206-807 891-8994/216-101 891-8994/216-102 891-8994/216-201 891-8994/216-202 891-8994/216-301 891-8994/216-302 891-8994/216-401 891-8994/216-402 891-8994/216-501 891-8994/216-502 891-8994/216-601 891-8994/216-602 891-8994/216-701 891-8994/216-702 891-8994/216-801 891-8994/216-802 891-8995/005-103 891-8995/005-105 891-8995/005-107 891-8995/005-203 891-8995/005-205 891-8995/005-207 891-8995/005-303 891-8995/005-305 891-8995/005-307 891-8995/005-403 891-8995/005-405 891-8995/005-407 891-8995/005-503 891-8995/005-505 891-8995/005-507 891-8995/005-603 891-8995/005-605 891-8995/005-607 891-8995/005-703 891-8995/005-705 891-8995/005-707 891-8995/005-803 891-8995/005-805 891-8995/005-807 891-8995/006-101 891-8995/006-102 891-8995/006-103 891-8995/006-105 891-8995/006-107 891-8995/006-201 891-8995/006-202 891-8995/006-203 891-8995/006-205 891-8995/006-207 891-8995/006-301 891-8995/006-302 891-8995/006-303 891-8995/006-305 891-8995/006-307 891-8995/006-401 891-8995/006-402 891-8995/006-403 891-8995/006-405 891-8995/006-407 891-8995/006-501 891-8995/006-502 891-8995/006-503 891-8995/006-505 891-8995/006-507
8918994/216802, 891 8994/216 802
