Datasheet Wago 891-8994/206-102 — Даташит
Соединительный кабель; Штекер - свободный конец; 4-пол.; длиной 1 м; Кодирование А; с изоляцией из ПВХ; Концы проводников, припаянные: 9 мм
891-8994/206-705 Wago | по запросу |
Coding | A |
Цвет | white |
Color of sheathed cable | white |
Conductor preparation | tip-bonded |
Connection type | Plug - free end |
Connector color | white |
Contact material | Copper or copper alloy, surface-treated |
Country of origin | PL |
Cross section of single conductor | 1.5 mm² |
Degree of protection | IP20 |
Durchmesser der Mantelleitung | 8.4 … 10.5 mm |
Fire load | 2.406 MJ |
GTIN | 4055143404334 |
Ground function | with preceding GND contact |
Locking lever | нет |
Locking of plug-in connection | locking lever |
Marking | N ⏚ 2|L 1|L' |
Mating force of a plug-in connection | approx. 20 … 70 N (depending on pole number) |
Mismating protection | Yes |
Number of Poles | 4 |
Pin spacing | 4.4 mm (0.173 inch) |
Potential marking | N ⏚ 2/L 1/L' |
Printing color of mating face | black |
Printing color of sheathed cable | black |
Printing color of strain relief | black |
Rated current | 16 A |
Rated impulse voltage (III / 3) | 6 kV |
Rated voltage (III / 3) | 400 В |
Reaction to fire class per EN 50575 | Eca |
Retention force of a plug-in connection | when locked: > 80N |
Sheath material | PVC |
Strain relief color | white |
Strip length | 45 мм |
Surrounding air (operating) temperature | -35 … 85 °C |
Total length | 1 m |
Total number of potentials | 4 |
Type of cable | H05VV-F 4G1.5 |
Type of cable assembly | Connecting cable |
Unmating force of a plug-in connection | when unlocked: approx. 20 … 70 N (depending on pole number) |
Вес | 140.125 г |
Серия: 891 (100 из 1377)
- 891-8994/106-702 891-8994/106-703 891-8994/106-705 891-8994/106-707 891-8994/106-801 891-8994/106-802 891-8994/106-803 891-8994/106-805 891-8994/106-807 891-8994/116-101 891-8994/116-102 891-8994/116-201 891-8994/116-202 891-8994/116-301 891-8994/116-302 891-8994/116-401 891-8994/116-402 891-8994/116-501 891-8994/116-502 891-8994/116-601 891-8994/116-602 891-8994/116-701 891-8994/116-702 891-8994/116-801 891-8994/116-802 891-8994/205-103 891-8994/205-105 891-8994/205-107 891-8994/205-203 891-8994/205-205 891-8994/205-207 891-8994/205-303 891-8994/205-305 891-8994/205-307 891-8994/205-403 891-8994/205-405 891-8994/205-407 891-8994/205-503 891-8994/205-505 891-8994/205-507 891-8994/205-603 891-8994/205-605 891-8994/205-607 891-8994/205-703 891-8994/205-705 891-8994/205-707 891-8994/205-803 891-8994/205-805 891-8994/205-807 891-8994/206-101 891-8994/206-102 891-8994/206-103 891-8994/206-105 891-8994/206-107 891-8994/206-201 891-8994/206-202 891-8994/206-203 891-8994/206-205 891-8994/206-207 891-8994/206-301 891-8994/206-302 891-8994/206-303 891-8994/206-305 891-8994/206-307 891-8994/206-401 891-8994/206-402 891-8994/206-403 891-8994/206-405 891-8994/206-407 891-8994/206-501 891-8994/206-502 891-8994/206-503 891-8994/206-505 891-8994/206-507 891-8994/206-601 891-8994/206-602 891-8994/206-603 891-8994/206-605 891-8994/206-607 891-8994/206-701 891-8994/206-702 891-8994/206-703 891-8994/206-705 891-8994/206-707 891-8994/206-801 891-8994/206-802 891-8994/206-803 891-8994/206-805 891-8994/206-807 891-8994/216-101 891-8994/216-102 891-8994/216-201 891-8994/216-202 891-8994/216-301 891-8994/216-302 891-8994/216-401 891-8994/216-402 891-8994/216-501 891-8994/216-502 891-8994/216-601
8918994/206102, 891 8994/206 102
