Datasheet Wago 891-8994/006-503 — Даташит
Соединительный кабель; Розетка - штекер; 4-пол.; Кодирование B; длиной 5 м; с изоляцией из ПВХ
891-8994/006-803 Wago | по запросу |
Coding | B |
Цвет | gray |
Color of sheathed cable | gray |
Connection type | Socket - Plug |
Connector color | gray |
Contact material | Copper or copper alloy, surface-treated |
Country of origin | DE |
Cross section of single conductor | 1.5 mm² |
Degree of protection | IP20 |
Durchmesser der Mantelleitung | 8.4 … 10.5 mm |
Fire load | 8.153 MJ |
GTIN | 4050821445852 |
Locking lever | нет |
Locking of plug-in connection | locking lever |
Marking | 1 2 3 4 |
Mating force of a plug-in connection | approx. 20 … 70 N (depending on pole number) |
Note on rated current | 13 A for 3-pole load10 A for 4-pole load |
Number of Poles | 4 |
Pin spacing | 4.4 mm (0.173 inch) |
Potential marking | 1 2 3 4 |
Printing color of mating face | black |
Printing color of sheathed cable | black |
Printing color of strain relief | white |
Rated current | 16 A |
Rated impulse voltage (III / 3) | 6 kV |
Rated voltage (III / 3) | 400 В |
Retention force of a plug-in connection | when locked: > 80N |
Sheath material | PVC |
Strain relief color | black |
Surrounding air (operating) temperature | -35 … 85 °C |
Total length | 5 m |
Total number of potentials | 4 |
Type of cable | Control line 4 x 1.5 |
Type of cable assembly | Interconnecting cable |
Unmating force of a plug-in connection | when unlocked: approx. 20 … 70 N (depending on pole number) |
Вес | 563.444 г |
Серия: 891 (100 из 1377)
- 891-8993/216-701 891-8993/216-702 891-8993/216-801 891-8993/216-802 891-8994/005-103 891-8994/005-105 891-8994/005-107 891-8994/005-203 891-8994/005-205 891-8994/005-207 891-8994/005-303 891-8994/005-305 891-8994/005-307 891-8994/005-403 891-8994/005-405 891-8994/005-407 891-8994/005-503 891-8994/005-505 891-8994/005-507 891-8994/005-603 891-8994/005-605 891-8994/005-607 891-8994/005-703 891-8994/005-705 891-8994/005-707 891-8994/005-803 891-8994/005-805 891-8994/005-807 891-8994/006-101 891-8994/006-102 891-8994/006-103 891-8994/006-105 891-8994/006-107 891-8994/006-201 891-8994/006-202 891-8994/006-203 891-8994/006-205 891-8994/006-207 891-8994/006-301 891-8994/006-302 891-8994/006-303 891-8994/006-305 891-8994/006-307 891-8994/006-401 891-8994/006-402 891-8994/006-403 891-8994/006-405 891-8994/006-407 891-8994/006-501 891-8994/006-502 891-8994/006-503 891-8994/006-505 891-8994/006-507 891-8994/006-601 891-8994/006-602 891-8994/006-603 891-8994/006-605 891-8994/006-607 891-8994/006-701 891-8994/006-702 891-8994/006-703 891-8994/006-705 891-8994/006-707 891-8994/006-801 891-8994/006-802 891-8994/006-803 891-8994/006-805 891-8994/006-807 891-8994/016-101 891-8994/016-102 891-8994/016-201 891-8994/016-202 891-8994/016-301 891-8994/016-302 891-8994/016-401 891-8994/016-402 891-8994/016-501 891-8994/016-502 891-8994/016-601 891-8994/016-602 891-8994/016-701 891-8994/016-702 891-8994/016-801 891-8994/016-802 891-8994/105-103 891-8994/105-105 891-8994/105-107 891-8994/105-203 891-8994/105-205 891-8994/105-207 891-8994/105-303 891-8994/105-305 891-8994/105-307 891-8994/105-403 891-8994/105-405 891-8994/105-407 891-8994/105-503 891-8994/105-505 891-8994/105-507 891-8994/105-603
8918994/006503, 891 8994/006 503
