Datasheet Wago 891-8993/215-302 — Даташит
Соединительный кабель; Штекер - свободный конец; 3-пол.; длиной 3 м; Кодирование А; безгалогенные; Концы проводников, припаянные: 9 мм
891-8993/205-107 Wago | по запросу |
Coding | A |
Цвет | white |
Color of sheathed cable | white |
Conductor preparation | tip-bonded |
Connection type | Plug - free end |
Connector color | white |
Contact material | Copper or copper alloy, surface-treated |
Country of origin | PL |
Cross section of single conductor | 1 mm² |
Degree of protection | IP20 |
Durchmesser der Mantelleitung | 6.3 … 8 mm |
Fire load | 4.112 MJ |
GTIN | 4055143397360 |
Ground function | with preceding GND contact |
Halogen-free | Yes |
Locking lever | нет |
Locking of plug-in connection | locking lever |
Marking | L ⏚ N |
Mating force of a plug-in connection | approx. 20 … 70 N (depending on pole number) |
Mismating protection | Yes |
Number of Poles | 3 |
Pin spacing | 4.4 mm (0.173 inch) |
Potential marking | L ⏚ N |
Printing color of mating face | black |
Printing color of sheathed cable | black |
Printing color of strain relief | black |
Rated current | 10 A |
Rated voltage (III / 3) | 250 В |
Reaction to fire class per EN 50575 | Eca |
Retention force of a plug-in connection | when locked: > 80N |
Strain relief color | white |
Strip length | 40 мм |
Surrounding air (operating) temperature | -35 … 85 °C |
Total length | 3 m |
Total number of potentials | 3 |
Type of cable | H05Z1Z1-F 3G1 |
Type of cable assembly | Connecting cable |
Unmating force of a plug-in connection | when unlocked: approx. 20 … 70 N (depending on pole number) |
Вес | 226.327 г |
Серия: 891 (100 из 1377)
- 891-8993/205-801 891-8993/205-802 891-8993/205-803 891-8993/205-805 891-8993/205-807 891-8993/206-101 891-8993/206-102 891-8993/206-103 891-8993/206-105 891-8993/206-107 891-8993/206-201 891-8993/206-202 891-8993/206-203 891-8993/206-205 891-8993/206-207 891-8993/206-301 891-8993/206-302 891-8993/206-303 891-8993/206-305 891-8993/206-307 891-8993/206-401 891-8993/206-402 891-8993/206-403 891-8993/206-405 891-8993/206-407 891-8993/206-501 891-8993/206-502 891-8993/206-503 891-8993/206-505 891-8993/206-507 891-8993/206-601 891-8993/206-602 891-8993/206-603 891-8993/206-605 891-8993/206-607 891-8993/206-701 891-8993/206-702 891-8993/206-703 891-8993/206-705 891-8993/206-707 891-8993/206-801 891-8993/206-802 891-8993/206-803 891-8993/206-805 891-8993/206-807 891-8993/215-101 891-8993/215-102 891-8993/215-201 891-8993/215-202 891-8993/215-301 891-8993/215-302 891-8993/215-401 891-8993/215-402 891-8993/215-501 891-8993/215-502 891-8993/215-601 891-8993/215-602 891-8993/215-701 891-8993/215-702 891-8993/215-801 891-8993/215-802 891-8993/216-101 891-8993/216-102 891-8993/216-201 891-8993/216-202 891-8993/216-301 891-8993/216-302 891-8993/216-401 891-8993/216-402 891-8993/216-501 891-8993/216-502 891-8993/216-601 891-8993/216-602 891-8993/216-701 891-8993/216-702 891-8993/216-801 891-8993/216-802 891-8994/005-103 891-8994/005-105 891-8994/005-107 891-8994/005-203 891-8994/005-205 891-8994/005-207 891-8994/005-303 891-8994/005-305 891-8994/005-307 891-8994/005-403 891-8994/005-405 891-8994/005-407 891-8994/005-503 891-8994/005-505 891-8994/005-507 891-8994/005-603 891-8994/005-605 891-8994/005-607 891-8994/005-703 891-8994/005-705 891-8994/005-707 891-8994/005-803 891-8994/005-805
8918993/215302, 891 8993/215 302
