Datasheet Wago 891-8993/206-401 — Даташит
Соединительный кабель; Штекер - свободный конец; 3-пол.; длиной 4 м; Кодирование А; с изоляцией из ПВХ; Концы проводников, припаянные: 9 мм
891-8993/206-605 Wago | по запросу |
Coding | A |
Цвет | black |
Color of sheathed cable | black |
Conductor preparation | tip-bonded |
Connection type | Plug - free end |
Connector color | black |
Contact material | Copper or copper alloy, surface-treated |
Country of origin | PL |
Cross section of single conductor | 1.5 mm² |
Degree of protection | IP20 |
Durchmesser der Mantelleitung | 7.4 … 9.4 mm |
Fire load | 7.831 MJ |
GTIN | 4055143396318 |
Ground function | with preceding GND contact |
Locking lever | нет |
Locking of plug-in connection | locking lever |
Marking | L ⏚ N |
Mating force of a plug-in connection | approx. 20 … 70 N (depending on pole number) |
Mismating protection | Yes |
Number of Poles | 3 |
Pin spacing | 4.4 mm (0.173 inch) |
Potential marking | L ⏚ N |
Printing color of mating face | white |
Printing color of sheathed cable | white |
Printing color of strain relief | white |
Rated current | 16 A |
Rated voltage (III / 3) | 250 В |
Reaction to fire class per EN 50575 | Eca |
Retention force of a plug-in connection | when locked: > 80N |
Sheath material | PVC |
Strain relief color | black |
Strip length | 40 мм |
Surrounding air (operating) temperature | -35 … 85 °C |
Total length | 4 m |
Total number of potentials | 3 |
Type of cable | H05VV-F 3G1.5 |
Type of cable assembly | Connecting cable |
Unmating force of a plug-in connection | when unlocked: approx. 20 … 70 N (depending on pole number) |
Вес | 432.055 г |
Серия: 891 (100 из 1377)
- 891-8993/205-201 891-8993/205-202 891-8993/205-203 891-8993/205-205 891-8993/205-207 891-8993/205-301 891-8993/205-302 891-8993/205-303 891-8993/205-305 891-8993/205-307 891-8993/205-401 891-8993/205-402 891-8993/205-403 891-8993/205-405 891-8993/205-407 891-8993/205-501 891-8993/205-502 891-8993/205-503 891-8993/205-505 891-8993/205-507 891-8993/205-601 891-8993/205-602 891-8993/205-603 891-8993/205-605 891-8993/205-607 891-8993/205-701 891-8993/205-702 891-8993/205-703 891-8993/205-705 891-8993/205-707 891-8993/205-801 891-8993/205-802 891-8993/205-803 891-8993/205-805 891-8993/205-807 891-8993/206-101 891-8993/206-102 891-8993/206-103 891-8993/206-105 891-8993/206-107 891-8993/206-201 891-8993/206-202 891-8993/206-203 891-8993/206-205 891-8993/206-207 891-8993/206-301 891-8993/206-302 891-8993/206-303 891-8993/206-305 891-8993/206-307 891-8993/206-401 891-8993/206-402 891-8993/206-403 891-8993/206-405 891-8993/206-407 891-8993/206-501 891-8993/206-502 891-8993/206-503 891-8993/206-505 891-8993/206-507 891-8993/206-601 891-8993/206-602 891-8993/206-603 891-8993/206-605 891-8993/206-607 891-8993/206-701 891-8993/206-702 891-8993/206-703 891-8993/206-705 891-8993/206-707 891-8993/206-801 891-8993/206-802 891-8993/206-803 891-8993/206-805 891-8993/206-807 891-8993/215-101 891-8993/215-102 891-8993/215-201 891-8993/215-202 891-8993/215-301 891-8993/215-302 891-8993/215-401 891-8993/215-402 891-8993/215-501 891-8993/215-502 891-8993/215-601 891-8993/215-602 891-8993/215-701 891-8993/215-702 891-8993/215-801 891-8993/215-802 891-8993/216-101 891-8993/216-102 891-8993/216-201 891-8993/216-202 891-8993/216-301 891-8993/216-302 891-8993/216-401 891-8993/216-402 891-8993/216-501
8918993/206401, 891 8993/206 401
