Datasheet Wago 891-8993/205-402 — Даташит
Соединительный кабель; Штекер - свободный конец; 3-пол.; длиной 4 м; Кодирование А; с изоляцией из ПВХ; Концы проводников, припаянные: 9 мм
891-8993/205-602 Wago | по запросу |
Coding | A |
Цвет | white |
Color of sheathed cable | white |
Conductor preparation | tip-bonded |
Connection type | Plug - free end |
Connector color | white |
Contact material | Copper or copper alloy, surface-treated |
Country of origin | PL |
Cross section of single conductor | 1 mm² |
Degree of protection | IP20 |
Durchmesser der Mantelleitung | 6.3 … 8 mm |
Fire load | 5.432 MJ |
GTIN | 4055143396011 |
Ground function | with preceding GND contact |
Locking lever | нет |
Locking of plug-in connection | locking lever |
Marking | L ⏚ N |
Mating force of a plug-in connection | approx. 20 … 70 N (depending on pole number) |
Mismating protection | Yes |
Number of Poles | 3 |
Pin spacing | 4.4 mm (0.173 inch) |
Potential marking | L ⏚ N |
Printing color of mating face | black |
Printing color of sheathed cable | black |
Printing color of strain relief | black |
Rated current | 10 A |
Rated voltage (III / 3) | 250 В |
Reaction to fire class per EN 50575 | Eca |
Retention force of a plug-in connection | when locked: > 80N |
Sheath material | PVC |
Strain relief color | white |
Strip length | 40 мм |
Surrounding air (operating) temperature | -35 … 85 °C |
Total length | 4 m |
Total number of potentials | 3 |
Type of cable | H05VV-F 3G1 |
Type of cable assembly | Connecting cable |
Unmating force of a plug-in connection | when unlocked: approx. 20 … 70 N (depending on pole number) |
Вес | 299.692 г |
Серия: 891 (100 из 1377)
- 891-8993/106-805 891-8993/106-807 891-8993/115-101 891-8993/115-102 891-8993/115-201 891-8993/115-202 891-8993/115-301 891-8993/115-302 891-8993/115-401 891-8993/115-402 891-8993/115-501 891-8993/115-502 891-8993/115-601 891-8993/115-602 891-8993/115-701 891-8993/115-702 891-8993/115-801 891-8993/115-802 891-8993/116-101 891-8993/116-102 891-8993/116-201 891-8993/116-202 891-8993/116-301 891-8993/116-302 891-8993/116-401 891-8993/116-402 891-8993/116-501 891-8993/116-502 891-8993/116-601 891-8993/116-602 891-8993/116-701 891-8993/116-702 891-8993/116-801 891-8993/116-802 891-8993/205-101 891-8993/205-102 891-8993/205-103 891-8993/205-105 891-8993/205-107 891-8993/205-201 891-8993/205-202 891-8993/205-203 891-8993/205-205 891-8993/205-207 891-8993/205-301 891-8993/205-302 891-8993/205-303 891-8993/205-305 891-8993/205-307 891-8993/205-401 891-8993/205-402 891-8993/205-403 891-8993/205-405 891-8993/205-407 891-8993/205-501 891-8993/205-502 891-8993/205-503 891-8993/205-505 891-8993/205-507 891-8993/205-601 891-8993/205-602 891-8993/205-603 891-8993/205-605 891-8993/205-607 891-8993/205-701 891-8993/205-702 891-8993/205-703 891-8993/205-705 891-8993/205-707 891-8993/205-801 891-8993/205-802 891-8993/205-803 891-8993/205-805 891-8993/205-807 891-8993/206-101 891-8993/206-102 891-8993/206-103 891-8993/206-105 891-8993/206-107 891-8993/206-201 891-8993/206-202 891-8993/206-203 891-8993/206-205 891-8993/206-207 891-8993/206-301 891-8993/206-302 891-8993/206-303 891-8993/206-305 891-8993/206-307 891-8993/206-401 891-8993/206-402 891-8993/206-403 891-8993/206-405 891-8993/206-407 891-8993/206-501 891-8993/206-502 891-8993/206-503 891-8993/206-505 891-8993/206-507 891-8993/206-601
8918993/205402, 891 8993/205 402
