Datasheet Wago 891-8993/105-602 — Даташит
Соединительный кабель; Розетка - свободный конец; 3-пол.; длиной 6 м; Кодирование А; с изоляцией из ПВХ; Концы проводников, припаянные: 9 мм
891-8993/205-107 Wago | по запросу |
Coding | A |
Цвет | white |
Color of sheathed cable | white |
Conductor preparation | tip-bonded |
Connection type | Socket - free end |
Connector color | white |
Contact material | Copper or copper alloy, surface-treated |
Country of origin | PL |
Cross section of single conductor | 1 mm² |
Degree of protection | IP20 |
Durchmesser der Mantelleitung | 6.3 … 8 mm |
Fire load | 8.067 MJ |
GTIN | 4055143747196 |
Ground function | with preceding GND contact |
Locking lever | нет |
Locking of plug-in connection | locking lever |
Marking | L ⏚ N |
Mating force of a plug-in connection | approx. 20 … 70 N (depending on pole number) |
Mismating protection | Yes |
Number of Poles | 3 |
Pin spacing | 4.4 mm (0.173 inch) |
Potential marking | L ⏚ N |
Printing color of mating face | black |
Printing color of sheathed cable | black |
Printing color of strain relief | black |
Rated current | 10 A |
Rated voltage (III / 3) | 250 В |
Reaction to fire class per EN 50575 | Eca |
Retention force of a plug-in connection | when locked: > 80N |
Sheath material | PVC |
Strain relief color | white |
Strip length | 40 мм |
Surrounding air (operating) temperature | -35 … 85 °C |
Total length | 6 m |
Total number of potentials | 3 |
Type of cable | H05VV-F 3G1 |
Type of cable assembly | Connecting cable |
Unmating force of a plug-in connection | when unlocked: approx. 20 … 70 N (depending on pole number) |
Вес | 445.509 г |
Серия: 891 (100 из 1377)
- 891-8993/015-501 891-8993/015-502 891-8993/015-601 891-8993/015-602 891-8993/015-701 891-8993/015-702 891-8993/015-801 891-8993/015-802 891-8993/016-101 891-8993/016-102 891-8993/016-201 891-8993/016-202 891-8993/016-301 891-8993/016-302 891-8993/016-401 891-8993/016-402 891-8993/016-501 891-8993/016-502 891-8993/016-601 891-8993/016-602 891-8993/016-701 891-8993/016-702 891-8993/016-801 891-8993/016-802 891-8993/105-101 891-8993/105-102 891-8993/105-103 891-8993/105-105 891-8993/105-107 891-8993/105-201 891-8993/105-202 891-8993/105-203 891-8993/105-205 891-8993/105-207 891-8993/105-301 891-8993/105-302 891-8993/105-303 891-8993/105-305 891-8993/105-307 891-8993/105-401 891-8993/105-402 891-8993/105-403 891-8993/105-405 891-8993/105-407 891-8993/105-501 891-8993/105-502 891-8993/105-503 891-8993/105-505 891-8993/105-507 891-8993/105-601 891-8993/105-602 891-8993/105-603 891-8993/105-605 891-8993/105-607 891-8993/105-701 891-8993/105-702 891-8993/105-703 891-8993/105-705 891-8993/105-707 891-8993/105-801 891-8993/105-802 891-8993/105-803 891-8993/105-805 891-8993/105-807 891-8993/106-101 891-8993/106-102 891-8993/106-103 891-8993/106-105 891-8993/106-107 891-8993/106-201 891-8993/106-202 891-8993/106-203 891-8993/106-205 891-8993/106-207 891-8993/106-301 891-8993/106-302 891-8993/106-303 891-8993/106-305 891-8993/106-307 891-8993/106-401 891-8993/106-402 891-8993/106-403 891-8993/106-405 891-8993/106-407 891-8993/106-501 891-8993/106-502 891-8993/106-503 891-8993/106-505 891-8993/106-507 891-8993/106-601 891-8993/106-602 891-8993/106-603 891-8993/106-605 891-8993/106-607 891-8993/106-701 891-8993/106-702 891-8993/106-703 891-8993/106-705 891-8993/106-707 891-8993/106-801
8918993/105602, 891 8993/105 602
