Datasheet Wago 891-8993/105-107 — Даташит
Соединительный кабель; Розетка - свободный конец; 3-пол.; Кодирование B; длиной 1 м; с изоляцией из ПВХ
891-8993/205-107 Wago | по запросу |
Coding | B |
Цвет | pink |
Color of sheathed cable | gray |
Conductor preparation | tip-bonded |
Connection type | Socket - free end |
Connector color | pink |
Contact material | Copper or copper alloy, surface-treated |
Country of origin | DE |
Cross section of single conductor | 1 mm² |
Degree of protection | IP20 |
Durchmesser der Mantelleitung | 6.3 … 8 mm |
Fire load | 1.473 MJ |
GTIN | 4050821622635 |
Locking lever | нет |
Locking of plug-in connection | locking lever |
Marking | 1 2 3 |
Mating force of a plug-in connection | approx. 20 … 70 N (depending on pole number) |
Number of Poles | 3 |
Pin spacing | 4.4 mm (0.173 inch) |
Potential marking | 1 2 3 |
Printing color of mating face | black |
Printing color of sheathed cable | black |
Printing color of strain relief | white |
Rated current | 10 A |
Rated voltage (III / 3) | 250 В |
Reaction to fire class per EN 50575 | Eca |
Retention force of a plug-in connection | when locked: > 80N |
Sheath material | PVC |
Strain relief color | black |
Strip length | 33 мм |
Surrounding air (operating) temperature | -35 … 85 °C |
Total length | 1 m |
Total number of potentials | 3 |
Type of cable | Control line 3 x 1 |
Type of cable assembly | Connecting cable |
Unmating force of a plug-in connection | when unlocked: approx. 20 … 70 N (depending on pole number) |
Вес | 78.973 г |
Серия: 891 (100 из 1377)
- 891-8993/006-602 891-8993/006-603 891-8993/006-605 891-8993/006-607 891-8993/006-701 891-8993/006-702 891-8993/006-703 891-8993/006-705 891-8993/006-707 891-8993/006-801 891-8993/006-802 891-8993/006-803 891-8993/006-805 891-8993/006-807 891-8993/015-101 891-8993/015-102 891-8993/015-201 891-8993/015-202 891-8993/015-301 891-8993/015-302 891-8993/015-401 891-8993/015-402 891-8993/015-501 891-8993/015-502 891-8993/015-601 891-8993/015-602 891-8993/015-701 891-8993/015-702 891-8993/015-801 891-8993/015-802 891-8993/016-101 891-8993/016-102 891-8993/016-201 891-8993/016-202 891-8993/016-301 891-8993/016-302 891-8993/016-401 891-8993/016-402 891-8993/016-501 891-8993/016-502 891-8993/016-601 891-8993/016-602 891-8993/016-701 891-8993/016-702 891-8993/016-801 891-8993/016-802 891-8993/105-101 891-8993/105-102 891-8993/105-103 891-8993/105-105 891-8993/105-107 891-8993/105-201 891-8993/105-202 891-8993/105-203 891-8993/105-205 891-8993/105-207 891-8993/105-301 891-8993/105-302 891-8993/105-303 891-8993/105-305 891-8993/105-307 891-8993/105-401 891-8993/105-402 891-8993/105-403 891-8993/105-405 891-8993/105-407 891-8993/105-501 891-8993/105-502 891-8993/105-503 891-8993/105-505 891-8993/105-507 891-8993/105-601 891-8993/105-602 891-8993/105-603 891-8993/105-605 891-8993/105-607 891-8993/105-701 891-8993/105-702 891-8993/105-703 891-8993/105-705 891-8993/105-707 891-8993/105-801 891-8993/105-802 891-8993/105-803 891-8993/105-805 891-8993/105-807 891-8993/106-101 891-8993/106-102 891-8993/106-103 891-8993/106-105 891-8993/106-107 891-8993/106-201 891-8993/106-202 891-8993/106-203 891-8993/106-205 891-8993/106-207 891-8993/106-301 891-8993/106-302 891-8993/106-303 891-8993/106-305
8918993/105107, 891 8993/105 107
